Overheating issues---PLEASE HELP
#31
Is the only differance between the manual and auto transmission the trans cooler? Can I put a manual radiator into the auto? All the ones I find state they are for manual. One example below, also....does it really matter if I buy a $300 of a $150 radiator, seeing as the specs are the same? I was looking at this.
http://cgi.ebay.com/ebaymotors/NISSA...item2a1269e909
#33
#35
Well in for an update.
I already had an aftermarket trans cooler on the car. I ordered an aluminum radiator and swapped that in on Sunday. It has been running GREAT! Nice and cool!! Im stoked the issue is finally solved! The old radiator must have had a blockage somewhere in it. It developed a leak right by the water neck the day I pulled it into the garage to switch them out.
joedaddy1
07-28-2015 02:58 PM
