Guage Pod above the AC display
Gauge Pod above the AC display
Hey, I was just thinking about a Gauge Pod that replaces the plastic ring of the AC display in our G35. Like a black plastic gauge pod that can fit 3 gauges (ex. water temp, oil temp, oil pressure). Has anyone done this? or any company making a product like this for easy install of aftermarket gauges? Because i reall like the 350z gauge style in the middle. And personally I hate the A pilller gauge pod since the roof line of the coupe is really low the gauges would be right in ur face so i was thinking of some new gauge pod ideas.
Any inputs?
Any inputs?
Originally Posted by etang789
Hey, I was just thinking about a Guage Pod that replaces the plastic ring of the AC display in our G35. Like a black plastic guage pod that can fit 3 guages (ex. water temp, oil temp, oil pressure). Has anyone done this? or any company making a product like this for easy install of aftermarket guages? Because i reall like the 350z guage style in the middle. And personally I hate the A pilller guage pod since the roof line of the coupe is really low the guages would be right in ur face so i was thinking of some new guage pod ideas.
Any inputs?
Any inputs?
I rejected the idea of a pillar mount as well and I'm not sure if I want to lose my heat/ventilation/AC info either.
Well my idea is not loosing the AC display...is just use the top part of it this is a very rough draft i mad the red box is just to help me draw haha ...well i measured the width and depth should be able to put 3 52mm gauges there no problem 60mm should be ok but the top and bottom is gonna stick out a bit and i think 60mm would be too big 52 should be just right...
here is a pic to show u guys
Any inputs?
Any inputs?
: http://www.forumshawaii.net/phpBB2/v...256572#1256572
Any inputs?
Any inputs?
Originally Posted by nismoGcoupe
I think it would look best on top of the cubby above the a/c controls that where I want to get mine installed when I go FI, you can get 3 guages in there if you angle them right.
Originally Posted by AltaLad
Yes that is my second choice for mounting some operational gauges. But I'm pondering just how much I really want to look at them and how much do I really want them in my way?
