Cooling fan motor question!
Old Sep 6, 2011 | 01:39 PM
Duriisimo's Avatar
Are both fan motors the same? Or are they side specific? If i need to buy a new fan motor does has to be driver/passenger side specific?
Old Sep 6, 2011 | 01:43 PM
Rich@GRUBBS's Avatar
PREMIUM SPONSOR
what year G35, coupe sedan?
Old Sep 6, 2011 | 01:45 PM
Duriisimo's Avatar
Sorry 06 Sedan
Old Sep 6, 2011 | 01:49 PM
PREMIUM SPONSOR
According to the system, they are specific to side, there are two different part numbers.
Phil
Old Sep 6, 2011 | 01:55 PM
Duriisimo's Avatar
Phil
damn, I recently bought this item for the driver side. Plugs in fine and turns on and off fine but I am having some heating cooling issues. You think this maybe an issue?
I see other OEM motors listed and described as L or R side
Old Sep 6, 2011 | 02:01 PM
PREMIUM SPONSOR
well, that number is good for Old G35 up to 06 Sedan, if you provide me your VIN either here or PM, i can tell you the correct part number and if this is it
Phil
Old Sep 6, 2011 | 02:06 PM
PREMIUM SPONSOR
I mispoke, I had the wrong vehicle in the system, that's why I looked for your VIN, the Jan 2002 to June 2007 manafacture date use the 21487-CD00A on both sides.... so depending on your manafacture date, that is the correct part.... sorry!
Phil
Old Sep 6, 2011 | 02:21 PM
Duriisimo's Avatar
Phil
ok, so fans are good, just now have to figure out whats causing the problem. Installed a new thermostat and still having issues.
Thanks
Old Sep 6, 2011 | 02:24 PM
rcdash's Avatar
Bleed air out of the coolant as per FSM
Old Sep 6, 2011 | 02:27 PM
Duriisimo's Avatar
I located the heater house bleeder, just need a DIY now. thanks
Old Sep 6, 2011 | 08:13 PM
Sylvan lake V35's Avatar
Yes air in the system is most likely the issue
nettcar
Aug 25, 2024 11:59 PM
Kng0fHrts
Sep 15, 2015 05:40 PM
Gookiecrunch
Aug 19, 2015 12:00 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
yassy
Aug 3, 2015 12:24 AM
