whats next??
whats next??
I got a G35 coupe 03 automatic
I did the the custom remap, k&N typhoon air intake, megan straight test pipes, y-pipe, invidia N1 catback exhaust, skunk2 1/2 engine Spacer... and im waiting for my transgo valve upgrade body kit and for obx crank underdrive pulley (lightweight),
but what do u advice next for better performance? should i remove some weight from the car?
You've got pretty much all the bolt-ons covered. Weight savings won't translate into much of a power/performance gain so your only 2 options left are Nitrous or going FI. You could squeeze a little more HP by building your motor, cams etc, but that route isn't worth the cost vs gains.
Forced Induction, things like supercharged, single turbo or twin turbo.
Trust me when I tell you that the only other non-forced induction option is to pull your engine and rebuild the motor and even then you'll be lucky to break the 300whp barrier.
Other than that you're SOL, sorry.
what about headers 3-1? or long tube? i want to keep it naturally aspirated for the time because my budget doest allow unless a used turbo... but my goal is to show a good difference between stock Gs and my G... plus i will make a better decision after i install the transgo valve body upgrade kit... i bought it and it will arrive soon... a friend of mine told me it will make a big difference in driving and much more fun...
