Engine stall at idle
Old Oct 5, 2011 | 10:24 AM
dnice7914's Avatar
I have a 03 g35 sedan. Recently I was driving my car in rush hour traffic. While I was idling and waiting to drive my car stalled out. I was able to start the car right away. I brought it to my local infiniti dealership. They hooked it up to the computer. They informed me that it didnt register any codes. No "check engine light" came on. They told me that I have a lazy O2 sensor. I'm wondering how they came to that determination if on codes were reported. Also while it was at the dealer the car did not stall out. Any help will be appreciated. thanks.
Old Oct 5, 2011 | 10:30 AM
PAIXAO's Avatar
I would try cleaning your MAF.
Old Oct 5, 2011 | 10:36 AM
herrschaft's Avatar
And inspect throttle-body
Old Oct 5, 2011 | 12:03 PM
dnice7914's Avatar
The dealer suposely cleaned the MAF. I will try to inspect the throttle body. Do you think it could be the O2 sensors?
Old Oct 5, 2011 | 12:14 PM
gary c's Avatar
It's possible it could be your 02 sensor, they're kinda flaky. It wouldn't hurt to clean or have your TB cleaned then make sure the MAF sensor is clean, don't assume they did it. What RPM does your G idle at? Should be close to 600 rpm, if it's to much lower you could do an idle reset....SEARCH!
Gary
Old Oct 5, 2011 | 12:18 PM
redpearl99's Avatar
did you first check the most obvious thing and see if your air filter is clogged to sh*t?
Old Oct 5, 2011 | 01:49 PM
dnice7914's Avatar
idle 750 - 650 rpm. Yes I checked the air filter its clean. Is there a DIY on how to clean the throttle body? What is a reasonable price to replace O2 sensors?
Old Oct 11, 2011 | 09:09 PM
Bl@ckHole's Avatar
I kinda have that same issue with my 04 coupe, but i have the Greddy TT, so I'm not sure if it's the same ball game....
Old Oct 17, 2011 | 04:53 PM
Z1Motorsports's Avatar
I would advise cleaning the throttle body by just removing it and spraying Carb/TB Cleaner in it until it appears clean (could take alot of cleaner) but you do not want to touch the blade if at all possible, I have seen to many cases of people opening the blade to clean the TB and end up having to replace it. They are very sensitive.
But from my experience a bad 02 would through a code, i believe a clean TB/MAF and Idle relearn will do the trick.
-Rob
Old Oct 17, 2011 | 04:55 PM
Your issue is slightly different, what EMS are you running?
Old Oct 17, 2011 | 08:14 PM
Bl@ckHole's Avatar
Not positive, lol...It's not the factory Greddy map that came with it, just a pro tune...It's really sparatic for me, every once and a while she just cuts off when i push the clutch in at low rolling speeds. I'm getting ready to clean the MAF and TB...It sat for a while, maybe that's why...
Old Oct 17, 2011 | 09:23 PM
Project's Avatar
Probably a tune issue with you. What size injectors are you running and fuel pump?
Old Oct 17, 2011 | 10:46 PM
Yea sounds like a tune issue, my car (APS TT) did the same thing when the idle was set to low. As a temporary fix you can run the AC all the the time (or atleast during low speed driving) it raises the idle enough to prevent that most of the time.
I highly suggest you pick up a PMAS and switch to Osiris, find a good pro tuner and it should not only make more power but drastically improve driveability.
-Rob
Old Oct 18, 2011 | 04:28 PM
Bl@ckHole's Avatar
Yea I know, I know the tuner at Turbo Xs in MD, so when I move back there shortly I'll be spending countless hours there!
Freeman186
Sep 6, 2023 10:07 AM
Joe Gargano
Sep 18, 2015 11:17 AM
esotericrider
Northern California
Sep 10, 2015 02:28 AM
Jnm07
Sep 5, 2015 01:16 AM
n2fooz
Sep 4, 2015 07:46 PM
