GT Spec's Lower Tie Brace
Old Dec 21, 2004 | 05:25 PM
SoCaliG35er's Avatar
Will these fit a G35 Coupe?
http://www.gtspec.com/products/viewp...id=77&T=12&M=4
http://www.gtspec.com/products/viewp...id=91&T=12&M=4
Old Dec 24, 2004 | 02:39 AM
SteveAreno's Avatar
I believe everything underneath both of the cars are the same (suspension parts, bolt holes etc.). You should still call the company before buying though.
Old Dec 24, 2004 | 08:49 AM
raysg35's Avatar
side to side it will fit, front to back you may have issues because of the different wheelbase.
Old Dec 24, 2004 | 10:28 PM
G35SanDiego's Avatar
Thats a good point. I know that the G is longr so that will obviously not fit but I also thought it was slightly wider? No? If so is the extra width from the suspension actually being mounted slightly wider or is it something smaller like a different offset? I am curious to becuase I have always had a soft spot for mods that increase the rigidity of the structural components.
Old Dec 26, 2004 | 04:07 AM
I measure each of the mounting points on the Z and their identical to the G. Not sure if the lower rear laterial tie brace will work, since it needs to hang below the exhaust...
Old Dec 27, 2004 | 12:37 PM
Gsedan35's Avatar
As noted all hard mounting points are the same suspension wise (of course G's do not have front STB mounting tabs at all). The front lower brace is extreamly difficult to install because those suspension bolts are either extreamly difficult to either get to and or difficult to loosen at home.
The rear lower brace doesn't work with some exhaust systems. See the thread talking about these product on my350Z.com to get a better idea.
alxmlr789
20 Inch
Jan 26, 2016 10:04 AM
boostelevator
Engine - Intake/Fuel
12
Jan 12, 2016 11:35 PM
EasySausage
Sep 24, 2015 01:06 PM
NJ6MT
Sep 10, 2015 08:40 AM
Kicknshift
Sep 3, 2015 09:35 AM
