Running Lean or Rich??
Old Nov 3, 2011 | 01:49 PM
GroundnPound's Avatar
I have looked all over the forums to see if I can avoid posting a simple question but I can't find a good answer to how I can tell if my car is running lean or rich? I have an 03 G35 Coupe with 64k miles on it, Motordyne Shockwave TDX2 catback, 5/16ths Intake manifold spacer and an injen CAI. I see a lot of people posting that their cars are running lean with similar mods, how do I tell? Thanks
Old Nov 3, 2011 | 02:00 PM
Canadian's Avatar
Canada, eh?
You can't tell without adding an air/fuel gauge. However, you've added nothing that would make your car run rich (ie more fuel) so if anything you will be on the leaner side (ie more air) but with your mods you're probably not far off of the stock air/fuel ratio.
Old Nov 3, 2011 | 02:10 PM
ok. I figured there was a quick response to that question. I have just started to put mods on the vehicle this summer and really don't want to cause any problems from lack of knowledge on secondary effects certain mods have. Thanks a lot!
Old Nov 3, 2011 | 02:12 PM
Canadian's Avatar
Canada, eh?
No problem. At some point you may consider getting a tune if you add more mods because you will get leaner the more bolt one you do. Plus you can gain probably 20whp with a tune if you have most bolt ons.
Old Nov 3, 2011 | 02:57 PM
right, I have been looking to do the Osiris tune, found a shop near me that is certified and seems to be a reputable place to get it done. I want to get ART test pipes before I do that though. Thanks for the tips
Old Nov 3, 2011 | 03:38 PM
Z1Motorsports's Avatar
As already stated you are likely on the lean side, but you should be fine as long as the car is well taken car of. As far as an Osiris tune, I HIGHLY recommend it once you've completed all your performance mods, but try to find a shop who does a lot of them, not just one that is "authorized" to do one, VQ oriented shops will generally provide a much better tune.
Let me know if I can ever help you with anything!
-Rob
Thebaws11
Jul 2, 2021 11:36 AM
Thebaws11
Nov 30, 2016 12:54 PM
Vqalexisz
Oct 14, 2015 12:48 AM
Rhinos7777
Sep 6, 2015 05:36 PM
