Clutch Chatter...
Old Nov 14, 2011 | 11:38 AM
Jiggyfingers's Avatar
Clutch Chatter...
When my car is in idle I hear a loud chatter from underneath the chassis. When I hold the clutch pedal in the chatter goes away. I really cannot tell if the clutch is aftermarket or if the throwout bearing is slowly on its way out. The clutch feels as if it grabs ok, no slipping, no odors, no heavy grinding during shifts.
Should I be cool?
Old Nov 14, 2011 | 11:41 AM
Texasscout's Avatar
Sounds like you may have an aftermarket "lightened" flywheel. The OEM "dual mass" flywheel (much heavier) does not do that.
Old Nov 14, 2011 | 11:48 AM
robisunreal's Avatar
I have the same problem, didn't notice it till it got cooler.
Old Nov 15, 2011 | 12:41 AM
HYDRUS's Avatar
^ Do you have an aftermarket flywheel also? Because mine does the same and was wondering if mine could also be. I was told everything was stock on the car and it looked stock also when i got it.
Old Nov 15, 2011 | 07:23 AM
Texasscout's Avatar
The OEM flywheel is designed to suppress the chatter. Almost all aftermarket FW will chatter.
Old Nov 15, 2011 | 09:27 AM
Is there an easy way to find out if I looked under the car? Probably not right?
Just picked up my car a month ago.
Old Nov 15, 2011 | 10:35 AM
HYDRUS's Avatar
Nope, theres no way to tell just looking under the car if you have an aftermarket clutch or flywheel.
Old Nov 18, 2011 | 06:52 AM
moto_za's Avatar
Is there a way to get rid of the chatter?? Other than going back to stock!
Old Nov 18, 2011 | 01:54 PM
Texasscout's Avatar
Unfortunately no.
Old Nov 22, 2011 | 07:49 PM
bythabay's Avatar
I had a stock flywheel since I bought my g new, and I always heard that same rattle you are describing.
Old Nov 25, 2011 | 01:05 PM
grazsrootz's Avatar
Mine had a pretty bad chatter stock, but it got worse once i got a lightweight FW
RichardP9
Drivetrain
Oct 26, 2015 11:25 PM
AL8782
Oct 3, 2015 10:26 AM
Jpete
Sep 25, 2015 01:38 PM
bigmike
Sep 17, 2015 01:58 PM
jbmw002
Sep 10, 2015 12:54 AM
