Need some advice for my NA build
Old Dec 11, 2011 | 11:19 PM
VQ35 revv's Avatar
Hey g35 driver.
I have a Canadian 2006 rev-up 6mt coupe with 40,000kms
Current mods are:
Stillen Z-Tube
Oil Catch Can
HKS drop in filter on the way.
My goals for this car are just to be a reliable DD with some more responsive power.
My future mods will be:
MREV2
5/16 spacer
Stillen exhaust
Test Pipes
With all these breather mods will I need a tune? Or can it be run safely on the stock ECU? Ive also considered headers but those things are a bitch to install so figured its not worth the trouble.
Also what do you guys think about the Godspeed HKS replica exhausts? those things are super cheap, but ive heard they have horrible fitment and just bad build quality...
Old Dec 11, 2011 | 11:23 PM
DrewDrew's Avatar
A tune isn't necessary, but it will yield ~20whp, and a smoother running engine via a fixed A/F ratio.
You're right about the headers - not worth the time and money for the small gains.
You get what you pay for with exhausts - those have terrible fabrication because they're so cheap. Stick with Stillen TD or Motordyne's TDX v2. Also tied in, the test pipes - MD's ART Pipes are bar none right now.
Old Dec 11, 2011 | 11:29 PM
VQ35 revv's Avatar
^^ sounds good man thanks.
I chose the stillen exhaust because i read it gives the best power gains compaired to others.
Cool il check out those test pipes too.
one more thing guys, I have that oil catch can installed, if I take the car in for warranty to check the oil consumption, do you think that would void it?
Old Dec 12, 2011 | 12:08 AM
VQ35 revv's Avatar
Wow I just check out those MD ART test pipes. Those things are crazy, I wonder why that little resonator helps so much in power..... Kinda weird, but I suppose they have tested their fluid mechanics on it and know that it flows good... Il definitely be adding those
Old Mar 31, 2012 | 05:29 PM
VQ35 revv's Avatar
Hey guys I am currently installing my MREV2 on my Revup 06 G35.
I was looking at the MREV2 compairing them and it looks to me like my stock revup lower plenum flows better???? Will the MREV2 help with power or should I sell it?? I am also currently adding the 5/16 spacer.
Thanks
Old Mar 31, 2012 | 09:17 PM
seymore4's Avatar
m56
To answer your most recent question yes the MREV2 flows better than stock, use it together with the spacer.
A catch can won't void your warranty, I had work done under warranty with full boltons and an ecu tune no questions asked.
What you listed is not an NA build... its some bolt ons. An "NA build" requires at a minimum cams, usually has hi comp pistons, stroker, etc. $10K plus range.
You don't "need" a tune, but it will give you more enjoyment and responsiveness than any of your other mods combined. Shoot, just syncing the throttle alone makes a huge difference.
Old Mar 31, 2012 | 11:05 PM
SDGenius's Avatar
since you're RevUp headers will actually give you some nice gains even w/o cams
Old Mar 31, 2012 | 11:08 PM
VQ35 revv's Avatar
Thanks for responces.
This is a bit of an old thread when i first got the car.
I think i might make this thread my new bulld one: https://g35driver.com/forums/tuner-d...ris-tuner.html
Fox843
Nov 7, 2015 05:43 PM
Rose M
Oct 12, 2015 10:00 AM
6spdGspot
Oct 5, 2015 01:55 PM
dcsbh1
Oct 1, 2015 03:15 PM
Learned Hand
Oct 1, 2015 09:02 AM
