Help, car won't start!!! Bad cam/crank sensor? Please help me diagnose
Old Jun 16, 2012 | 11:58 AM
nadjkovic's Avatar
Originally Posted by Tolboothwilley™
Non-start issues are often from lack of communication from ECU to the Key.
Sensors going bad often exhibit symptoms before going out.
Mine will occasionally start and run extremely rough when it does. As far as symptoms, I had sputtering, loss of power, and hard starts prior to mine breaking down. Uploading a video now of how it's running.
Old Jun 16, 2012 | 01:18 PM
nadjkovic's Avatar
Old Jun 17, 2012 | 11:21 PM
EverybodyWildOu's Avatar
Originally Posted by nadjkovic
That's weird. You should run the code and see what comes up. Pull your plugs and see if they're fouled as well.
Old Jun 18, 2012 | 12:25 PM
nadjkovic's Avatar
SES code was 0603, and that's just from having the negative battery terminal unhooked for too long because it was transported across country while I moved.
Anyway, I already replaced the spark plugs with NGK Iridium IXs
This is my diag thread: https://g35driver.com/forums/engine-...wont-idle.html
Guess what? I had taken it to the dealer, and they're gunna charge me $470+ to replace the fuel pressure regulator. -_- & they said that they don't even know if that's gunna fix it.. I'm irate. I can throw parts at it all day! That was next on my list! ****
chinee
Jun 10, 2024 07:48 PM
Hasanbaloch
Feb 29, 2024 08:45 PM
newg37
Jul 26, 2015 09:32 AM
itschuckster
Jul 25, 2015 08:07 AM
