Oil Leak
Old Feb 13, 2012 | 01:44 PM
Pooks14's Avatar
Oil Leak
I just replaced my Spark Plugs this last weekend. When I pulled the coil pack for the number 6 plug, it was dripping in oil. (is it possible that this is due to the whole "excessive oil consumption) I am going to try replacing the valve cover gaskets this weekend. Also now when accelerating between 3000-5000 RPMs it is now sluggish and bogs down.
I also believe that I have a vacumm leak not sure but I hear this sucking noise around the number 2 plug area. Im not too sure about the vacumm leak because I know that if there is one then the car will idle roughly which it is not. Is the computer able to adjust if it detects a vacumm leak? Im going to go buy some carb cleaner and try to find the leak if there is one.
Any ideas what could be causing this?
Old Feb 13, 2012 | 04:47 PM
Pooks14's Avatar
Ok so I figured out why it was bogging down and was sluggish. I disconnected the wiring to the Throttle body, but I didnt reset the ECU. I feel stupid for not realizing this earlier..
Old Feb 13, 2012 | 06:40 PM
superchargedg's Avatar
A simple search would have solved the problem with oil leaking into #6 cylinder
Old Feb 13, 2012 | 06:47 PM
Pooks14's Avatar
Yea I know that now, I'm new to this fourm, and can only get on it at work (search function will never finish loading)
But I found the thread and ordering the new valve covers now.
Old Feb 13, 2012 | 09:43 PM
Xx AzN xX's Avatar
same problem here.... smh
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
mbe32
Nov 13, 2015 11:09 PM
BradMD_96
Oct 6, 2015 09:31 AM
hrdwirk1
Oct 2, 2015 06:34 PM
vamarris
Sep 26, 2015 12:56 PM
