car hesitates under full throttle help plz
Old Apr 11, 2012 | 03:59 PM
G35-31's Avatar
hey guys i have a 2006 rev up engine , mods stillen catback, cai ,mrev2, stage 3 clutch with 16lb flywheel. under 75% or more throttle the car like hesitates and then it takes a sec to finally kick in . it doesnt always happen but its like a 50/50 chance usually wont do it for 10 mins then the other 10 it will. i thought it might be the maf sensor so i changed that still nothing , i was thinking maybe the throttle body is bad? or could it be from bad plugs? i took it to the local autozone and they checked everythingout it wasnt throwing any codes other then the cats 02 sensors wherent there which i do have them unpluged because the hook up isnt the same on the harness . what could this be from ?
Old Apr 11, 2012 | 04:49 PM
That's G's Avatar
The only time I've ever experienced this happening on a car is when I had a cracked intake hose on one of my old POS cars. Car had the same symptoms, but threw no codes.
Old Apr 12, 2012 | 07:31 PM
G35-31's Avatar
check the hoses all are good.
Old Apr 13, 2012 | 09:48 AM
onevoice's Avatar
Does your car 'buck'? I had the problem and it turned out to be the camshaft AND crankshaft sensors. It gave the code for the crankshaft sensor but not camshaft sensor
Old Apr 13, 2012 | 10:05 PM
G35-31's Avatar
well it didnt throw any code, but i wouldnt call it a buck its acts like the car is spinning tires and the vdc kicks in then gets back in it
Hasanbaloch
Feb 29, 2024 08:45 PM
wonderizm
Sep 24, 2015 03:09 AM
ghost_g35
Aug 7, 2015 10:31 AM
Detailed Image
Jul 24, 2015 12:31 PM
quickspeed6
24
Jul 15, 2015 11:06 AM
