starting issues
Old Jul 15, 2012 | 05:08 PM
islandtuner242's Avatar
Originally Posted by maxpusher
Does the car fire right up after it has been warmed up? Or is it still the same? This happened to me in another vehicle. The fuel pump was working but was relieving pressure slowly so when I tried to start the car up in the morning or it has been sitting it would take awhile to fire up. Make sure fuel pressure is holding after the car has been sitting. There was a port where I could hook up a harbor freight fuel pressure gauge and test and fuel pressure on the fuel rails. I am not sure how the G35 is setup.
no matter how long the car sits it does the same thing.... i could crank it up shut it off and crank it right back up again and it does the same thing
Old Jul 16, 2012 | 09:15 PM
maxpusher's Avatar
20 Year Member
Sounds to me like a sensor issue. Is there any check engine codes that you get?
Old Nov 6, 2012 | 05:16 PM
Ndianx's Avatar
my car has being doing the same thing recently. I have long cranking times as the video. I have a 05 g35 coupe. I do not know what the problem can be? Any Help?
Old Nov 7, 2012 | 08:26 PM
it came back with the camshaft position sensor code but i have yet to change all three at one time due to me being sent 2 of the exact same kind of camshaft position sensor (both straight none with an angle) so now i have to re-order my sensors
chinee
Jun 10, 2024 07:48 PM
Terry_G35
May 9, 2020 01:39 AM
MyfistYourFace
Aug 8, 2015 11:58 AM
D1dphresh
Aug 7, 2015 06:10 PM
itschuckster
Jul 25, 2015 08:07 AM
