My vq35de blew. Can i swap it with the vq35hr motor?
I have an 06m35x. Should i just get another vqde, or if i get a new ecu, can i put the vq35hr motor in there. I know it'll fit in there for sure, but is the main structure identical? Will it mount in fine with the stock mounts and connect to my headers and everything?
Not true, a company by the name of Zfever already did it.
Zfever will do all the wiring for you
Yes and no, as i mentioned above a comany called zfever already put an HR in a 05 g35 coupe he needed the engine harness, dash harness, HR ECU, motor and tranny. Now im making it sound easier than it is it took them 3 solid days of wiring to convert everything over ive already priced out the swap your looking at about 5500 bucks for parts and labor and thats without the price to actually drop the motor and tranny in. I was going to do it but when i saw how much it cost versus the power youl get its just not worth it im just going to build the block and boost it.
Ironwrench22 (05-03-2024)
