uprev for hp tq over 600??
Old Jun 14, 2012 | 11:01 PM
N8Deezy's Avatar
Has anyone who has the uprev software tuned their car for 600whp or more??
Old Jun 15, 2012 | 11:44 PM
350z006's Avatar
Yes I have; Uprev can definitely handle over 600whp...the limiting factor with Uprev since its MAF tuned is that you'll need an upgraded MAF, or a bigger MAF pipe....if you don't want to get a bigger MAF pipe then I suggest getting the PMAS MAF, good to 1000hp
Old Jun 16, 2012 | 12:25 AM
seymore4's Avatar
m56
I'm at 570whp, with no problems, I have a friend that was making 690 then upgraded his turbos and cams and finally went haltech.
You will need an uprev Maf GT for anything over 400 or so, they quit making the PMAS.
Old Jun 18, 2012 | 02:18 AM
N8Deezy's Avatar
Ok. i'm trying to sort this out because I'm doing a custom setup. So it seems I can run a single intake but a larger diameter intake pipe. Or run a dual intake which requires 2 MAFS. I was trying to avoid a haltech because of how few tuners that support the system. I know of a few places who are uprev certified.
Old Jun 18, 2012 | 02:32 AM
seymore4's Avatar
m56
Either way I believe the stock maf will max out, the intake pipe won't be a problem there are plenty of guys making that kind of power without a larger diameter pipe, even if you did get a larger one the throttle body would be a restriction
Old Jun 18, 2012 | 02:39 AM
N8Deezy's Avatar
Which MAF does the JWT kit utilize then? I do also understand the airflow properties with respect to your last statement
Old Jun 18, 2012 | 03:00 AM
seymore4's Avatar
m56
Depends on the kit but Id bet everyone running the 700 or 850 kit is using an HPX or Uprev GT
Old Jun 18, 2012 | 12:36 PM
seymore4's Avatar
m56
If you need a maf gt I've got a brand new one I'll sell you, hpx mafs pop up every now and then used in the classifieds but not often
Old Aug 2, 2012 | 06:09 AM
Dark-Knight's Avatar
I may run into a similar issue after my motor gets rebuilt and I up the boost. How much does a MAF Gt retail for and where can I purchase one online?
Old Aug 2, 2012 | 12:19 PM
seymore4's Avatar
m56
$350 plus shipping from uprev
Old Aug 10, 2012 | 03:25 PM
N8Deezy's Avatar
After doing my hwk, I found that you only need 1 MAF GT. Uprev sells them and it rated to 1000hp.
Old Aug 14, 2012 | 02:06 PM
350z006's Avatar
Are you sure? Where does it say it's rated to 1000hp?
Old Aug 21, 2012 | 04:54 PM
N8Deezy's Avatar
My statement was incorrect, I spoke to Uprev directly and they reported hearing of a customer hitting 750hp. I think the hp rating I was thinking of was the FMIC that you can order from GTM. Their side suggests support up to 1000hp. My bad
Old Aug 21, 2012 | 04:56 PM
N8Deezy's Avatar
Don't know if I mentioned this before but this is in regards to a VQ35DE revup motor
DEMoLITIoN
Audio/Video/Electronics
Apr 20, 2016 06:57 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
ZoominG35
Oct 12, 2015 04:53 PM
onlyhuman
Engine - Electrical
Sep 21, 2015 12:28 PM
pdexta
Tuner & Dyno
Sep 2, 2015 01:03 PM
