throw out bearing
Old Jul 2, 2012 | 09:09 PM
Lartytiejdke3's Avatar
throw out bearing
whats up guys.
question here. stock clutch on a 05 6mt. almost 99% the Throw out bearing is goin bad. clutch still grabs and shifts smooth but i got that rattling when i let off the throttle at low rpms.
also would this problem with the TOB cause the "service engine soon" light to come on?? cuz it is.....
Old Jul 8, 2012 | 12:28 AM
G35_DAN's Avatar
Don't think you have a release bearing problem. Check your engine oil level...the DTC you have may be a result of that.
Just my 2 cents...
Old Jul 13, 2012 | 03:54 PM
ConradoR's Avatar
You know when your throwout bearing is going bad when you hear a like faint grinding noise every other second. (it should go away when the clutch pedal is pressed the whole way down)
Old Jul 13, 2012 | 04:41 PM
Gdoser's Avatar
It could be flywheel chatter possible
Old Jul 13, 2012 | 08:48 PM
Tolboothwilley™'s Avatar
bearing should not cause a CEL I don't believe...I think you need to post up your code and go from there
Dallsinghjr1
Sep 17, 2023 11:25 AM
Marlin84
Apr 1, 2020 12:52 PM
Claudiu
V36 Brakes, Suspension, Wheels & Tires
Mar 10, 2018 11:38 AM
atomevolution
Engine - Exhaust
Oct 12, 2015 01:00 PM
AL8782
Oct 3, 2015 10:26 AM
