high pitched whining when A/C is on
Old Sep 12, 2012 | 09:31 AM
adman101's Avatar
I recently started hearing a high pitched whining that goes with the gas and the gear shifts only when the A/C is on. when it is off it goes away. Someone told me its a grounding issue but sounds like bs
some one chime in. thankss!
Old Sep 12, 2012 | 04:19 PM
dukehotty's Avatar
Check your belts before anything else!
Old Sep 14, 2012 | 08:39 AM
adman101's Avatar
already tightened my belts but its not that type of whining. i can only hear it from inside the car it seems
Old Sep 15, 2012 | 03:19 PM
adman101's Avatar
anyone??? 04 5AT
Old Sep 15, 2012 | 05:34 PM
DrivenG's Avatar
i get this from time to time as well. GOing back a few years people were calling it the ghost turbo for our cars. It can get annoying i just ignore it now and still have no idea why its there lol .
Old Sep 15, 2012 | 06:24 PM
leanlikeacello's Avatar
Mine does this too
Old Sep 17, 2012 | 06:45 PM
adman101's Avatar
i usually have my music up so it doesnt bother me but it is annoying when i need quiet with the windows up
Old Sep 18, 2012 | 02:23 PM
icekewl's Avatar
mouse is living in the heat exchanger..
Old Sep 26, 2012 | 11:24 AM
hectorwilliamz's Avatar
i believe it is the ac compressor bearing mine does the same thing.
Old Oct 1, 2012 | 05:31 PM
kcasner's Avatar
That, or the idler pulley. You can use a long screwdriver as a probe, to pinpoint bad bearings. Put the screwdriver point on the compressor closest to the pulley, and the handle against your ear while the car is running. Same thing for the idler, but you can use the fixed bolt in the center up front.
Check each one, even if you think you've found the one with the distinct sound. If it's loud enough to hear in the car, it should stand out.
Disclaimer:
Don't be "that guy" who has long hair or loose clothing, bring common sense when doing this.
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
atomevolution
Engine - Exhaust
Oct 12, 2015 01:00 PM
Learned Hand
Oct 1, 2015 09:02 AM
Jcruzg35
Sep 26, 2015 04:47 PM
