Piston compression question.
Old Jan 19, 2005 | 09:42 AM
roneski's Avatar
Devil's Advocate
Question Piston compression question.
Why would you want to go to a lower compression piston? I imagine that it has something to do with protecting the engine for forced induction applications, but can someone clarify for me?
Old Jan 19, 2005 | 11:39 AM
ChicagoX's Avatar
Don't drink and Mag Race
Under boost, the lower compression piston is less prone to detonation (preignition). It also allows you to run a lower octane for the same boost level, if desired (keeping it a pump-gas motor, for example).
Old Jan 19, 2005 | 11:42 AM
roneski's Avatar
Devil's Advocate
Ahhhh... ok, now it makes perfect sense. Thanks.
Old Jan 19, 2005 | 11:46 AM
nnkfws333's Avatar
Check out www.howstuffworks.com and they do a very good illustration of turbos and stuff.
Old Jan 19, 2005 | 01:49 PM
KPierson's Avatar
Boost makes more power then compression. To simplify things when you 'boost' a motor you are effectively raising the compression ratio. If the compression ratio is high already you will run into issues because your over all compression will be higher then your fuel can maintain.
If you lower your compression you can raise your boost. low compression + high boost will make more power then high compression + low boost.
Old Jan 19, 2005 | 06:30 PM
Blackbird V35's Avatar
dont forget to add that when you lower compression it will affect spool up and hp per psi
a higher compression motor will make more hp per psi than a low compression one
Old Jan 19, 2005 | 08:05 PM
KPierson's Avatar
Yes, I guess I just assumed that people knew that the higher your compression ratio the more HP you will make! Sorry for leaving that out. I work in NW Indy!
Old Jan 20, 2005 | 12:19 AM
i was just trying to cover all bases on this post.
im from the south side of indy, do you live in indy?
Old Jan 20, 2005 | 12:59 AM
KPierson's Avatar
The more detailed the better!
I live in Dayton, but the company I work for is on the NW side of Indy
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
prinny
Nov 22, 2015 11:07 PM
The Fixer
Steering & Suspension
Nov 1, 2015 03:26 PM
dcsbh1
Oct 1, 2015 03:15 PM
