Misfire with no code and new coils and spark plugs
Old Sep 24, 2012 | 10:50 AM
SuperG118's Avatar
Alright so I had a misfire in my car 2 weeks after I got a new short block installed. Righ after the install everything was perfect and 2 weeks later got a misfire and check engine light. Had all 6 coils replaced and the code went away and it ran perfect. Now a week later the car is missing again randomly tho (ill start it and it will misfire, drive around and it clears, and comes back randomly, some times it's fine at start up but then driving it starts missing bad). I replaced all spark plugs and same issue.
The car hasn't thrown a code and not sure why. I checked all vacuum hoses and no leaks I can tell.
Any ideas what would cause the car to misfire randomly and not throw a code?
Old Nov 18, 2015 | 09:22 PM
btran35's Avatar
Did you end up finding out the problem?
Old Dec 2, 2015 | 03:13 PM
telcoman's Avatar
Veteran: Army
Read the FSM
http://www.nicoclub.com/FSM/G35/Coupe/2003/ec.pdf
See Pages EC-290,291, 292,293,294
Diagnostic Procedure
ABS003CO
1.
CHECK FOR INTAKE AIR LEAK AND PCV HOSE
1. Start engine and run it at idle speed.
2. Listen for the sound of the intake air leak.
3. Check PCV hose connection.
OK or NG
OK >> GO TO 2.
NG >> Discover air leak location and repair.
2.
CHECK FOR EXHAUST SYSTEM CLOGGING
Stop engine and visually check exhaust tube, three way catalyst and muffler for dents.
OK or NG
OK >> GO TO 3.
NG >> Repair or replace it
Just replacing parts and guessing is not proper troubleshooting
Good luck
Telcoman
Telcoman
Old Sep 27, 2020 | 11:00 PM
Raul Garcia's Avatar
G35 sedan
Originally Posted by telcoman
Read the FSM
ABS003CO
1.
OK or NG
OK >> GO TO 2.
2.
OK or NG
OK >> GO TO 3.
Good luck
Telcoman
Telcoman
whats next after this? Been having this problem and I've checked vacuum system for leaks checking exhaust tomorrow
Old Sep 28, 2020 | 10:43 AM
andrewl_v35's Avatar
04.5 G35 Sedan 5AT
I'd check the evap solenoid and the small vacuum hose on the rear of the intake plenum.
Jasper_
May 22, 2018 06:27 PM
Bean_VQ35DE
Dec 4, 2015 07:41 AM
GD-Up
Apr 4, 2010 11:30 PM
F1Flagger
Feb 6, 2010 10:38 AM
Eric@TCGMiami
Jan 23, 2009 06:14 PM
