Check engine code
Old May 13, 2009 | 07:53 PM
F1Flagger's Avatar
Check engine code
I have a check engine code p507.
Which has to do with idle speed.
Any known issues as to what might be wrong?
I have noticed an increase the past few days of the idle speed.
Thanks in advance for any help!
Old May 18, 2009 | 11:59 AM
pwebb's Avatar
possible causes:
electronic throttle control actuator
intake air leak - you'll be able to hear it - usually
pcv system - loose hose
how many miles on your car?
any modifications?
recent work done?
Old May 18, 2009 | 03:09 PM
fbpem1's Avatar
what year is the car? more info is needed to make an accurate diagnosis on the vehicle.
Old May 26, 2009 | 07:17 AM
F1Flagger's Avatar
Sorry guys for not getting back. Out of town on business.
The car is an 04 with 96,000.
I will check to see if I hear leaks when running.
Old May 27, 2009 | 08:52 PM
pwebb's Avatar
well my bet is that the throttle body is all caked with gunk.
probably needs a good cleaning. but after this is done, the ECU will need to learn its idle. this is known as an Idle Air Volume Learn. dealer can do this for you. if you're a good customer they might not charge you.
I feel like there is some info floating around on how to manually get the ECU to learn its idle. I couldnt tell you.
Old Jan 23, 2010 | 10:22 PM
vp-g's Avatar
I have this code also can anyone tell me how to reset or get the ecu to learn the idle??
this happened after I cleaned the TB and installed a ztube. I reinstall the stock iar intake but the light is still on??? even after I disconnect the battery..
Old Jan 26, 2010 | 12:36 AM
Tollboothwilley's Avatar
do a search for "idle relearn procedure" make sure your sort by "relevance"
High idle = normally a bad throttle body or just bad calibration
Low idle = normally a vacuum leak, could be pcv valve
If you cleaned your TB then you need to reset your idle via the reset procedure. Many people have had issues after cleaning it where they could not get the TB to relearn idle air volume. This happened to me. I had to buy a new one.
Old Jan 26, 2010 | 07:18 AM
vp-g's Avatar
problem sloved relearn helped. been driving for 3 day now no light idle is at 650 rpm. thanks
Old Feb 6, 2010 | 10:38 AM
Pratt's Avatar
sweeeet good deal
Muski_G
Dec 1, 2023 11:11 AM
ara777
Aug 15, 2018 04:11 AM
Kng0fHrts
Sep 15, 2015 05:40 PM
ClwMike
Jul 23, 2015 12:55 PM
Jadenkid22
Jul 14, 2015 12:33 AM
