belt broke.. Car hesitates to start now.. Help
Old Oct 15, 2012 | 11:55 PM
Patriotsfan5660's Avatar
I have a problem meybe someone can guide me In The right direction. I have an 03 sedan and today the belt that goes to the ac compressor and tentioner pulley broke.. Well made it home and changed the belt. Now the car hesitates to start, I have to try a few times before it starts and the check engine, slip, and tracktion control lights are on. After it starts it runs fine, no problems. Idk why it's doin that just bc of the belt. It's been running like a champ before no problems at all. Any ideas of what could be causing the problem, what's wrong.
Old Oct 16, 2012 | 01:33 AM
joedaddy1's Avatar
did you check the tension on the new belt?
too tight? too loose?
Old Oct 16, 2012 | 08:40 AM
Yea they look feel fine..
Old Oct 16, 2012 | 10:47 PM
i went to autozone and got the codes erased too see if the belt made them trip.. well after erasing them. the car cranked right up no prioblems at all.. a few hours later it started doin the same thing again. not wanting to start and all 3 lights came back on
Old Oct 17, 2012 | 01:27 AM
Tolboothwilley™'s Avatar
Why did the belt break? If it was recently replaced it could have been too tight - causing excess tension on things.
If the SES light is on, you should check the error codes and see what they say.
Check your oil level as well. Its very possible that something else is going on simulaneously (doubt it but ya never know). Low oil level and Low brake fluid can kick those lights.
Old Oct 17, 2012 | 01:51 PM
i checked all the pulleys to make sure none where stuck. and they are all fine. the new belts are fine, no squeaking or too tight. i guess the belt was going bad and it just broke.. the oil level is fine and so is the brake fluid..
Old Oct 18, 2012 | 01:43 PM
CBRworm's Avatar
20 Year Member
Make sure the belt didn't break a cam/crank sensor wire or sensor itself.
CBRworm's Avatar
20 Year Member
What was the code?
Old Oct 19, 2012 | 08:03 AM
ok so i finnally got a chance to get the codes pulled and it was the p0340 i believe. and it was the camshaft sensor.. reading on here i found out it was bank one, passenger side behind the heads.. well i went to autozone and bought one and i'll be damn.. that was the problem. started right up. i still dont know how the belt caused it to go bad.. bc the sensor is in the back so the broked belt couldnt have even touched it.. but shes fixed for now. Thanks everyone for the trouble shooting tips..
chinee
Jun 10, 2024 07:48 PM
newg37
Jul 26, 2015 09:32 AM
itschuckster
Jul 25, 2015 08:07 AM
kenthung
Jul 21, 2015 05:56 AM
realtalk21
Jul 20, 2015 09:07 AM
