New member. Need advice on valve cover job.
Old Oct 19, 2012 | 01:55 AM
SDInfinitiG35's Avatar
I am a new member here and I recently purchased a 2003 g35 sedan with 140,000 miles on it. As I was doing a major tune up i noticed oil on the spark plugs. This would indicate that the valve cover gaskets will need to be replaced. Seems like this is a common issue on these cars, but is it as simple as replacing just the gaskets or do other parts need to be replaced as well? I am a Volkswagen mechanic so although I am mechanically inclined I am not too familiar with Nissan engines. Anything to look out for before I jump into this project?
Old Dec 22, 2012 | 01:20 AM
mrgrey's Avatar
Yea go to this site, they sell just the O-rings, have a machine shop install
rndfactory.com
Way way cheaper and good prodcuts.
Old Dec 28, 2012 | 07:57 AM
tle.88's Avatar
There should be a "do it yourself guide" on here just search for it. Well it will make the job easier and will tell you what is needed.
Old Jan 8, 2013 | 12:59 PM
onevoice's Avatar
My mechanic told me to clean out the oil and then check the wells again after a few thousand miles. If the oil hasn't returned then you are probably fine, but if the oil has built up to the same level as previously then you need to replace them.
Not a difficult task especially since you are a mechanic. There is a DIY on this site
Old Jan 8, 2013 | 01:07 PM
mrgrey's Avatar
Your mechanic does not understand the concept. the o - rings are bad. You need a new pcv valve too.
Old Jan 8, 2013 | 04:30 PM
saywat?'s Avatar
i wouldnt waste my time doing the job twice or more by jus cleaning the sparkplug housing and seeing if it occurs again cus it will. unless u enjoy that sort of thing. me personally, my back cant handle it lol
bryanr
Drivetrain
Sep 30, 2015 06:31 AM
UndyingDest
Drivetrain
Sep 7, 2015 12:49 AM
johnadlertech
Engine - Complete Motors
Sep 6, 2015 12:45 PM
UT G35
Sep 3, 2015 03:58 PM
