07/08 G35 Rear Axle on 03 G35 Coupe
Old Oct 25, 2012 | 10:10 AM
gun6kill's Avatar
Hey guys, found myself in a weird position. Basically messed up and ordered an 07 Rear Hub Assembly for my 03 G35 Coupe. Assembly bolted up fine and feels great, only issue is that the 03 Rear Axles Spline on the end doesn't sit inside the Hubs splines tight enough. So my question is will the 07/08 Right Rear Axle Bolt up on my 03. My rear axle is pretty rough anyway so i figure just replacing it with an 07/08 Axle will be the easiest method.
Any information will be greatly appreciated, Thanks guys
Old Oct 25, 2012 | 11:48 AM
Tolboothwilley™'s Avatar
you're probably right - this is not something most people do though
the differentials are the same though, so i see no reason why this wont work
Old Oct 25, 2012 | 01:51 PM
gun6kill's Avatar
Thanks for the reply man, i figured it would work. Just wanted to get a few other opinions on it
TWASkyliner
Feb 8, 2020 08:00 PM
teamghost
Jul 28, 2015 04:52 PM
crazy_g35s
Jul 20, 2015 02:30 PM
