have you checked your plugs?
Old Jan 23, 2005 | 06:34 PM
RedondoG's Avatar
My Iridium plugs (which are 1 step colder) look as though the engine is running lean (even though I just had this dyno'ed and the air/fuel curves look great.
The standard NGK plugs had a nice coffee with cream color but these Iridium plugs look white with a hint of gray. Have any of you ever pulled your plugs to check their color as an indicator of how your engine is running?
Old Jan 23, 2005 | 06:50 PM
Msedanman's Avatar
O.F. Administrator
You're right, it sounds like the plugs are too hot or the mixture too lean.
Last time I checked plugs was in my G-Sedan and they were light tan.
Old Jan 23, 2005 | 08:12 PM
nuttyprof's Avatar
how do you check em? ill go try later and let u know what color mine are.
Old Jan 23, 2005 | 10:33 PM
JDM V35's Avatar
Thumbs up My Stock NGK plugs after 1900 miles W/Super Charger
Here are my stock plugs after 1900 miles with the supercharger. I fouled out one of the plugs because the car runs rich right now. I just installed new ones a week ago and then found out about the one step cooler NGK Iridium plugs. I just ordered and picked the Iridium’s Today.
David G
Attached Thumbnails have you checked your plugs?-ngk-stock.jpg   have you checked your plugs?-ngk-1.jpg   have you checked your plugs?-ngk-2.jpg
Old Jan 23, 2005 | 10:53 PM
nuttyprof's Avatar
so what do the iridium plugs do for you?
would they help me in anyway?
Old Jan 24, 2005 | 12:25 PM
ARH_twilightblue's Avatar
^^ I would like to know as well...
Old Jan 24, 2005 | 02:32 PM
cato's Avatar
SouthernComfort Moderator
I want to know how to get to the plugs. A DIY pictorial would be GREAT!
Old Jan 24, 2005 | 02:56 PM
RedondoG's Avatar
This is the #4 plug from my car
Old Jan 24, 2005 | 04:55 PM
Msedanman's Avatar
O.F. Administrator
A DIY pictorial on plug access and change is a good idea, just too time consuming for me right now. If someone else can step up, that would be great.
It involves accessing the plug areas, moving some wiring and plumbing, disconnecting the coils, and finally 'digging' out the plugs with a good plug wrench and extension.
Some plugs are much easier than others.
Definitely a biotch of a job, but not insurmountable.
C.
Old Jan 24, 2005 | 05:22 PM
nuttyprof's Avatar
dang it. on my prelude, it was a cinch.
Old Jan 24, 2005 | 06:36 PM
FrizzleFry's Avatar
just be glad you don't have transverse mounted v6 like in alot of domestic.s 1991 Cutlass sumpreme w/ a v6... had to "lift/rotate" the motor on its mounts just to get to the back plugs. good thing on the 99 alero, it was a bit easier. no lifting of the motor.
Old Jan 24, 2005 | 06:40 PM
JDM V35's Avatar
I do a DIY when I install my new plugs.
(GSEDANMAN) You want me to send it to you? And in what format?
David G
Old Jan 25, 2005 | 12:01 AM
nuttyprof's Avatar
send me one too. i dont care what format.
Old Jan 25, 2005 | 12:09 AM
RedondoG's Avatar
nuttyprof;
If your anywhere near Redondo Beach, come by and I'll walk you through it.
Old Jan 26, 2005 | 11:10 PM
dwoloz's Avatar
I may come see you sometime RedondoG, Im in Manhattan Beach
