Cosworth oil pump... worth it?
Old Dec 3, 2012 | 09:34 AM
hipi2002's Avatar
I have an 06 Sedan that I plan to mod out some when I return from overseas. I'm sticking with NA, running full exhaust, cams, and a few other things. Wondering if a cosworth hi-pressure oil pump is worth it or should i spend it elsewhere? Suggestions?........
Old Dec 3, 2012 | 09:50 AM
HotRodG35's Avatar
Unless you plan on revving engine over 7800 RPM its not worth it.
Just use a OEM Rev-Up oil pump if your concerned with high RPM oiling, commonly used with FI builds.
Old Dec 6, 2012 | 09:21 AM
eZg's Avatar
eZg
+1 everything I've read says use rev up, which is what is on my built motor
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
mbe32
Nov 13, 2015 11:09 PM
Visionnn
Oct 3, 2015 05:16 AM
9tray turbo
Sep 29, 2015 10:22 PM
wow600rr
Sep 28, 2015 11:50 AM
