Pulley bearings going bad??
Old Dec 5, 2012 | 04:28 AM
Footballmania32's Avatar
Angry Pulley bearings going bad??
Hey guys,
Over the past few weeks I've had a chirping/high pitched soft squeak developing on cold starts. It is not squealing like a belt in need of tensioning. *It originated from what looks to be the idler pulley/alternator pulley area. Took a real good listen around and I think I have it fairly isolated. I took a video to help better covey the noise to you guys. *Im doing a major maintenance in two weeks, so I wanted to go ahead and order any parts I may need now. Take a listen. Any trouble shooting will help greatly!
Additional info, belts were changed at Infiniti 6 months ago. Noise goes away after 20 minutes of driving roughly 55mph. I.e. the noise will often stick around 10-15 minutes after it has been at operating temp. Other times, I have to really get on it doing a customary WOT 1st-2nd high rpm pull for it to go away, and this is after the initial 20 minutes of driving.
TIA.
Old Dec 5, 2012 | 07:54 PM
05_SkylineSedan's Avatar
20 Year Member
I needed to replace one of my belt tensioner idler pulleys which was doing a similar thing. I guess they can wear out like any bearing...
While I was at it I removed the redundant idler pulleys on both our '05 and '06 Gs. (EDIT: 05-06 still had the mechanical fan pulley even though it was an electrical fan. Not sure when that change happened... ) Here's a thread on that subject (not my own):
https://g35driver.com/forums/engine-...-mod-pics.html
You need a spacer if you pull the whole thing out ,or you can leave that small corner of the bracket if you decide to cut it... I didn't do it myself but the it didn't take the shop much time at all. I can't claim any gain in HP or mileage (Ha!) but it seems like a cleaner layout with the 1" shorted belt.
Old May 22, 2013 | 05:48 PM
mrsmith4ever's Avatar
Did you ever figure out what this was? My 2007 is making the same noise.
Old May 24, 2013 | 08:58 PM
Skyline_G35's Avatar
English dude, English
Mine is once again making that noise. It happens every 2 years for me ever since I went supercharged. I've replaced the idler pulley on the alternator side 3 times now. I'm going on my forth one. The bearings in this little guy suck! At 40 a pop, they aren't cheap either. Thats just for the pulley. I change it out myself since the closest infiniti dealership is 40 min away and I really don't feel like paying for something I can do in 1 hrs time.
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
linedr89
Engine - Power Adders
Oct 4, 2015 07:29 PM
reaper76
Sep 20, 2015 11:59 AM
G35-2004-mt6
Sep 11, 2015 04:16 PM
