New JDM HKS ST Build but what are these parts ?
Old Dec 15, 2012 | 11:33 PM
R6n350GT's Avatar
So engine builder only had enough time to pull engine out of car, build new one but i have to put it all back in...
Pics of Engine
Now i get given my car back no engine or any parts inside the bay, and a box of bolts... great, where do these all go..
I found this tread so it will help somewhat but appreciate if anyone can identify and let me know and i can then figure out the rest hopefully!!!!
https://g35driver.com/forums/engine-...olt-sizes.html
Thanks very much, i appreciate it !
Old Dec 15, 2012 | 11:44 PM
Th3R3dStar323's Avatar
Where are you located? You need to find someone who knows what they are doing to help you put this motor back in.
You run out of money to pay the guy to put it back in?
Old Dec 15, 2012 | 11:48 PM
jim9's Avatar
Damn that sucks... From the picture looks like it could of taken the guy another day then motor is in. Hope something works out.
Old Dec 16, 2012 | 01:42 AM
R6n350GT's Avatar
Located in Australia..
He had the engine and all parts and machine done for 3 months, i said why are you delaying finishing, he said cause i dont have time to do it all, sooo i said just finish the engine, ill deal with the rest..
No one this close to xmas wants to touch it, i can do it but if i took engine out i would have labled all the bolts in bags etc..
Just incase it helps someone here is some of the ones i figured out
^^ I am updating what i have found, ill add yours to my list in a sec, thanks so much!!!
edit: wow you are awesome, btw ps, alternator, a/c are all still on old engine so no brackets, bolts/nuts should be in that pic.
trans and drive shaft also taken out
Engine didnt come with coil packs
(I brought this engine a year ago and it didnt have a few bits and pieces which im taking off my un-built engine fyi)
red = Guilty1s
green = friend of mine
1: ?
2: ?
3: ?
4: ?
5: ?
6: Sump plate
7: ?
8: ?
9: ?
11: Coolant cross over
12: Plenum inner
13: Front of the under body splash guard
14: ?
15:?
16: ?
17: ?
18: Sump
18: ?
20: driving lights nuts
21: driving light spacers
22: ?
23: ?
24: Plenum outer
25: Tail shaft
26: ?
27: Idler Pulley
28: upper bell housing
29: lower bell housing
31 & 32: Battery bracket
33a: ?
33b: lower 4 are for that front black radiator support bracket
34: Shifter spring
35: Coolant cross over bracket (attached to timing chain cover)
36: Evap solenoid
37: to cover the lower left bell housing hole (opposite side of alternator, as its RHD)
38: Harness bracket (where does this attach to?)
39: Engine mount nuts
40: ?
41: Radiator hose
42 & 43: Vaccume lines
44: coolant lines for oil filter housing/cooler
44: cam cover breather hose?
Any other help would be awesome
Old Dec 17, 2012 | 01:58 AM
dukehotty's Avatar
Takes it out and rebuilds but won't/ can't put it back in!? WHO THE FK DOES THAT!? I would have never taken a job that huge to someone that wouldn't finish it. Good luck though!
Old Dec 26, 2012 | 12:08 AM
laksjd84's Avatar
try to distinguish via service manual.
believe it or not, there is a service manual for engine placement.
bolts should be easy since the manual tells you the length and thread pitch of bolts.
thread measuring ruler will def. help here.
GL
jsimonk
Dec 22, 2023 03:49 PM
itztwinki3
Steering & Suspension
Aug 18, 2015 03:38 PM
Karl_g335x
Aug 3, 2015 03:43 PM
.cakestar
Audio/Video/Electronics
Jul 17, 2015 08:22 PM
