Engine Ticking Please help !!!
Old Mar 1, 2013 | 12:35 AM
Jabaree12's Avatar
Originally Posted by deezee101
Had the same problem.. Shims were worn down!
So how did you go about getting it fixed ? And what was the price range for you
Old Mar 1, 2013 | 12:55 AM
deezee101's Avatar
This was with my last G .. It was under warranty so I paid nothing.. they said it was a 1300 job. I had the same sound.. Not sure if that helps but get a opinion from a expert that specializes with shims and buckets in these cars. Its a shitty design in my opinion. GL! the shims and buckets are 26.00 a piece. If this is the case it would be cheaper to repair than replace a whole engine. Its hard to tell from the video.. but get a stethoscope $7.00 at advanced... and see if you can hear it on one side and not the other, then at least you know its coming from the top end. if you feel loss of power then its a bigger deal.
Old Mar 1, 2013 | 01:05 AM
deezee101's Avatar
Ill send a video to my tech. all he does is works on these cars.... It sounds like the top end. worst maybe a piston slap or some dammage on the cams. Doesnt sound like rod or bearing. I will get back with you tom. Once I send the video. How many miles on the motor?
Old Mar 1, 2013 | 01:14 AM
Jabaree12's Avatar
I dont feel any engine power loss the car seems to run fine its just that noise . The car is going on 130k miles ! Thanks a lot also
Old Mar 1, 2013 | 12:20 PM
deezee101's Avatar
I sent the video to my tech. He also thinks its the shims. Has it had engine work. If the shims are put incorrectly thats the sound you get.
Old Mar 2, 2013 | 06:59 PM
Jabaree12's Avatar
I dont think it has but today i bought a stethoscope and when i was moving it around everything sounded the same but when i put it on the fuel rail and injectors it was really loud but i just changed my injectors about 3 weeks ago
Old Mar 3, 2013 | 12:39 PM
deezee101's Avatar
I have heard of loud injectors. I would go get it checked out man. it sounds like the shims .. not the motor.. GL lmk what you figure out.
Old Mar 25, 2013 | 02:21 AM
Jabaree12's Avatar
Ok i finally took the motor apart now i am getting familiar with the parts are the shims the shiny plastic caps overtop the spring ? Or at those the lifters?
Old Mar 25, 2013 | 05:00 AM
HotRodG35's Avatar
VQ engines do not have lifters. The part your referring to is the valve bucket/cam follower which sits directly on top of valve spring.
Shims is not the proper term for valve bucket/cam followers.
Old Mar 25, 2013 | 09:25 AM
Jabaree12's Avatar
So why does it say remove the valve lifters in the service manual?
Old Mar 25, 2013 | 09:35 AM
Jabaree12's Avatar
And where can i purchase the valve buckets/can follower
Old Mar 25, 2013 | 09:47 AM
HotRodG35's Avatar
I stand corrected, FSM does call them lifters. Aftermarket generally refers to OHC setups as cam followers.
The rest is still correct, no shims but LIFTERS. I need to review the FSM again its been 3 years since doing any top end maintenance.
If you decide to go with aftermarket Lifters (cam followers) than Supertech are better priced than OEM.
Old Mar 26, 2013 | 01:25 AM
Jabaree12's Avatar
Ok thanks a lot i will let you know how it goes
Freeman186
Sep 6, 2023 10:07 AM
alessandro
Oct 8, 2015 09:29 AM
Joe Gargano
Sep 18, 2015 11:17 AM
AT23
Sep 15, 2015 07:44 PM
AuAltima3.5
Sep 13, 2015 10:53 AM
