03 G sedan shuts off when stopped
Old Feb 25, 2013 | 10:44 PM
BlkGSedan's Avatar
Does anyone know why when i come to a stop my car shuts off but still has power on the dash and when i try starting it again it has a loud click i cant figure out what it is
Posted from G35driver.com App for Android
Old Feb 26, 2013 | 09:40 AM
bluedevils95's Avatar
Is your RPM going under 500?
Old Feb 26, 2013 | 09:45 AM
BlkGSedan's Avatar
I havent looked at the rpms but normally its above
Old Feb 26, 2013 | 09:58 AM
BlkGSedan's Avatar
It stays by 500 when im at a complete stop
Old Feb 26, 2013 | 10:28 AM
You might need to clean your TB. That would be my guess. I am hoping someone w/ this same problem can chime in.
Old Feb 26, 2013 | 12:58 PM
Tolboothwilley™'s Avatar
I doubt its a TB related problem
Its much more like to be the common problem of a failing cam phase sensor - there are 2, one on each valve cover towards the firewall
Sometimes you won't get a CEL until it fails completely, but you should have the codes run, just in case there is a pending.
Other than the random stops is it running normal? How many miles?
Old Mar 11, 2013 | 11:40 PM
yoyo221's Avatar
it could be something involving your fuel system like the fuel filter,fuel lines,fuel sensor,fuel injectors,fuel pump.when you come to a complete stop something is cutting your fuel.
chinee
Jun 10, 2024 07:48 PM
Muski_G
Dec 1, 2023 11:11 AM
madmax032
Drivetrain
Jan 18, 2016 10:41 AM
chinee
Aug 8, 2015 10:11 AM
apintojr
Jul 23, 2015 10:52 AM
