Captain needs help . Engine idle problems. What does this sound like
Old Mar 12, 2013 | 04:18 PM
Exclamation Captain needs help . Engine idle problems. What does this sound like
Have been having very rough idle problems for the last couple of months , and Finally have time to try to figure it out. On cold start, car idles fine . Once warmed up , car starts vibrating crazy at 6500 RPM. Idle seems to go up and down as well . Rough idle is most noticeable at a red stop light , and even crazier when going reverse .
Started by cleaning the TB, was a little dirty, but nothing over the top. I also included a vid , checked the engine mounts, seemed fine . Car's idle is so rough you can feel it by touching any exterior part .
Car sounds like it also has a vacuum leak, so currently taking off both plenums and hoses and retightening everything
Any clue?
http://www.flickr.com/photos/61136499@N06/8551800961/http://www.flickr.com/photos/61136499@N06/8551800961/ by http://www.flickr.com/people/61136499@N06/, on Flickr
http://www.flickr.com/photos/61136499@N06/8552902324/http://www.flickr.com/photos/61136499@N06/8552902324/ by http://www.flickr.com/people/61136499@N06/, on Flickr
http://www.flickr.com/photos/61136499@N06/8551800321/http://www.flickr.com/photos/61136499@N06/8551800321/ by http://www.flickr.com/people/61136499@N06/, on Flickr
http://www.flickr.com/photos/61136499@N06/8552901532/http://www.flickr.com/photos/61136499@N06/8552901532/ by http://www.flickr.com/people/61136499@N06/, on Flickr
http://www.flickr.com/photos/61136499@N06/8552900578/http://www.flickr.com/photos/61136499@N06/8552900578/ by http://www.flickr.com/people/61136499@N06/, on Flickr
Old Mar 12, 2013 | 04:30 PM
hopesNdreamz's Avatar
for some reason my computer wont let me see the vid. did you check your air filter? sometimes if its real clogged up it can cause a rough idle. maybe check the sparks too?
Old Mar 12, 2013 | 04:43 PM
but dont take my word on that, thats just my $.02 haha i would probably wait for a more qualified answer than mine
Old Mar 12, 2013 | 05:32 PM
Put everything together only to hear this
Wtf
Old Mar 12, 2013 | 05:38 PM
Frankieg35's Avatar
Omg that scared the **** out of me.. lol
Old Mar 12, 2013 | 05:46 PM
JaE35's Avatar
Moderator
G35 Sedan
wow i have no clue
Old Mar 12, 2013 | 05:52 PM
my good friend works at Stillen in the import dept. his name is kenny, im sure if you call stillen and ask for him he will be able to direct you better. he is a genius when it comes to imports and engine issues. his ext is 185
Old Mar 12, 2013 | 06:07 PM
That G Gray's Avatar
the heck.. never seen something like this before. Sounds like timing or vacuum leak
Old Mar 12, 2013 | 06:39 PM
JaE35's Avatar
Moderator
G35 Sedan
Post this on my350
Old Mar 12, 2013 | 07:23 PM
Took everything off and put everything back on.
Same ****
Old Mar 12, 2013 | 07:29 PM
petesg35's Avatar
Are all cylinders firing it sounds like its only running on three cylinders.
Old Mar 12, 2013 | 08:05 PM
How would I be able to tell?
Old Mar 12, 2013 | 08:20 PM
G35SHAWN's Avatar
damn that is not good, my advice contact greengoblin aka Danny i am sure he can pin point the problem.
Old Mar 12, 2013 | 08:22 PM
N8Deezy's Avatar
Have you plugged it into a scanner and see if it's throwing any codes? Vacuum leak on that second video possibly?
Old Mar 13, 2013 | 02:28 AM
vegaszx10's Avatar
When you cleaned the throttle body, did you push the butterfly with your finger to clean it? If you did then start with calibrating your throttle position sensor. Remember the gas pedal is all electronic you can't clean it like the regular ones., Then do a vacuum test to see if there's a vacuum leak, but sounds like random misfire.
Jiggerjuice
Oct 5, 2015 02:33 PM
03sedang35
Aug 29, 2015 07:56 PM
derres
Aug 28, 2015 03:27 PM
Phenomenon9
Aug 9, 2015 01:34 AM
ghost_g35
Aug 7, 2015 10:31 AM
