Can you Paint the Stock Plenum???
Old Jan 27, 2005 | 03:04 PM
qmaster8's Avatar
Can you paint the stock engine upper plenum? If I use the Dupli-Coat high temp spray paint (1200 degrees)?
Is this safe to do or will it chip?
Thanks.
Jason
Old Jan 27, 2005 | 04:30 PM
CLS2G35's Avatar
try powder coating may work out better.
Old Jan 28, 2005 | 09:34 AM
madchef's Avatar
I have def seen it done. But since I haven't done it myself, I'm not sure what they used.
Old Jan 28, 2005 | 12:27 PM
Kyosho's Avatar
i've seen polished plenums also. they look really nice but if i remember correctly take a few hundred to do.
Old Jan 28, 2005 | 03:53 PM
Diesel1's Avatar
Moderator
Also, polished metal holds heat better than non-polished. Just something to consider. Although it looks very sharp IMO, there is a slight trade off.
Old Jan 28, 2005 | 04:05 PM
CLS2G35's Avatar
Polishing reduces surface area.
Old Feb 8, 2005 | 10:30 AM
Brando's Avatar
Thumbs up
[QUOTE=qmaster8]Can you paint the stock engine upper plenum? If I use the Dupli-Coat high temp spray paint (1200 degrees)?
My vote is yes you can!
The prep work is the key. Completely clean it with solvent and a wire brush.
I used the High Temp Ceramic and then baked it in my friends kiln at 350 degrees for 3 hrs. to make it super hard, so it should not chip.
Old Feb 8, 2005 | 10:36 AM
pdjafari's Avatar
[QUOTE=OldVFRGuy]
Daaang VFRguy, that looks pretty niiiiiiiiiiiiice!!!
Old Feb 8, 2005 | 02:16 PM
njsfastestg's Avatar
G SQUAD
looks good but don t forget the heat resiant clear coat. i did my covers in red and black and it looks sick. the clear coat is the key to the shine.i did 3 coats of clearcoat. good luck
Old Feb 8, 2005 | 04:09 PM
Brando's Avatar
Actually....I did not want "shine".
I was after more of a matt, powder coated look.
Also, the paint has ceramic in it to dissipate heat evenly. The clear coat messes it up and makes it hold more heat.
jsimonk
Dec 22, 2023 03:49 PM
Daniel k.
Nov 3, 2015 09:52 AM
Raven7
Aug 14, 2015 04:40 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
