Replaced radiator and its overheating
Old Mar 29, 2013 | 11:53 PM
504's Avatar
504
So Sunday noticed radiator was leaking from the top plastic between the aluminum, as if the top plastic was coming apart. I it got replaced today and when I picked it up it started overheating.. The car never overheated before the replacement. Waiting for it to cool down to check the coolant.. What can it possibly be if it never overheated before its an 04 sedan 83k miles.. Thanks for the help...
Old Mar 30, 2013 | 12:06 AM
nism0b0y's Avatar
It sounds like you have air in the system, old cars didn't matter if you had air in the coolant system, our cars have overheating issues if there's air in the system, take it back to the shop and tell them they need to bleed the air out, if you did the install see if you can find a DIY on getting air out of the cooling system..
Hope this helps out man.
Old Mar 30, 2013 | 07:28 AM
Blue Dream's Avatar
I drove ttrank's car solo
The G is notorious for being difficult to bleed properly. Take it back to the mechanic and have him bleed the system until the bottom radiator hose gets hot, that's a good sign the system is functioning properly.
Old Apr 3, 2013 | 12:11 AM
marrero's Avatar
I'd replaced my radiator today and everything is fine except that when I turn on the heater. It didn't not get hot at all. How do I bleed the radiator?
Old Apr 3, 2013 | 04:12 PM
B T's Avatar
B T
remember to reconnect the rad fan?
KevinnnVo
Oct 14, 2024 04:33 PM
tiguy99
Mar 1, 2016 11:42 AM
Felipe Gonzalez
Aug 16, 2015 10:02 AM
yassy
Aug 3, 2015 12:24 AM
joedaddy1
Jul 28, 2015 02:58 PM
