What am I hearing?
Old Apr 4, 2013 | 10:11 PM
RockyR87's Avatar
What am I hearing?
A couple of weeks ago I topped off my coolant to avoid the temperature spiking again. A little while after I noticed this noise like I'm driving through water. It only occurs below 3k rpm or if I let off the gas. At first it was only here and there, but now it seems to happen constantly. What's causing this and how do I fix it?
Old Apr 5, 2013 | 07:11 AM
Blue Dream's Avatar
I drove ttrank's car solo
You have air in your cooling system. That what's causing the heating issue and the sound of running water which I assume you hear up under the dash. Bleed the system to release the air and you should be good.
Old Apr 5, 2013 | 09:45 AM
RockyR87's Avatar
Well I know one thing I'll be doing today
Old Apr 5, 2013 | 12:37 PM
RockyR87's Avatar
So I had the job done and left the garage and everything seemed to be in working order. Five mins later..noise is there again. Took it back to them and one of their guys said it may be a timing chain guide. Any thoughts?
Edit: Found this: http://www.6mt.net/forum/g35-coupe/3...-problems.html Describes my exact problem.
Dallsinghjr1
Sep 17, 2023 11:25 AM
Marlin84
Apr 1, 2020 12:52 PM
Patrick Bovee
Oct 1, 2015 10:42 AM
Jeff T
Sep 30, 2015 02:00 PM
alinero718
Sep 27, 2015 09:35 PM
