P0335
Old Apr 22, 2013 | 10:19 PM
G235's Avatar
P0335
I have a 2005 g35 that doesn't start easily, misfires, poor performance, engine vibration and the RPM isn't steady, I've used a diagnostics tool and it said that it has P0335 (crankshaft position sensor), so I've replaced my crankshaft position sensor and restarted my ECU and it didn't help and the code is still on.
I've asked Scotty Kilmer the guy that makes car repairing videos on youtube, and he replied by saying that some times the timing chain is stretched and causes error readings to the ECU.
is that true? should i change my timing belt or there are other things i should check first?
sorry for my bad english
Old Apr 23, 2013 | 08:25 AM
Blue Dream's Avatar
I drove ttrank's car solo
There are 2 camshaft position sensors that will sometimes throw this code when they go bad. I'd start with replacing both of them and see if the issue goes away. I've owned my car for 4 years and haven't met 1 person that has had to replace the timing chain (not belt) so I doubt that's causing the issue. How many miles are on your car?
Old Apr 23, 2013 | 06:41 PM
G235's Avatar
It has about 200K miles, I'll try replacing them before next week.
Thanks Blue Dream
Batfinity
22
Aug 12, 2022 12:18 PM
06g35
Feb 14, 2022 05:59 AM
Jeff M.
Apr 20, 2015 08:26 AM
dohcofthebay
Feb 10, 2015 05:35 PM
aa2033
Sep 21, 2014 04:22 AM
