low idle, engine wont turn over w/o revving
Old May 26, 2013 | 05:58 PM
minhpho's Avatar
so i just changed the spark plugs on my dads 2004 g35 and followed the DIY guide on this site. However when we went to go start it up the engine wouldnt turn over. when i gave it gas when i started the engine it would turn over but the rpms would be at the very bottom line barely keeping the engine going. I made sure everything was connected correctly and i tried a ecu reset as well as a throttle body reset. im stumped now any help??
Old May 26, 2013 | 06:45 PM
roaminggnome's Avatar
If it ran fine before you did the plugs. Then something didn't get hooked back up right. Could be you have one or more of the plugs going to the coils crossed. I would go back over everything again. And make sure that you didn't forget something.
Old May 26, 2013 | 07:05 PM
minhpho's Avatar
i dont think its that because i made sure the right connectors went to the right socket by labeling them. i also double checked that everything was connected and nice and snug
Old May 26, 2013 | 08:33 PM
N8Deezy's Avatar
I wouldn't look past going over everything again, especially if the car was running fine before you changed the plugs. I would also do the relearn process again, you never know it might be that simple.
Old May 26, 2013 | 08:36 PM
minhpho's Avatar
true that, ill do that when i have a chance today and hopefully thatll fix it
Muski_G
Dec 1, 2023 11:11 AM
Phenomenon9
Aug 9, 2015 01:34 AM
keithk831
Steering & Suspension
Aug 2, 2015 09:50 PM
Roblee22
Jul 30, 2015 12:11 PM
richmc
Jul 26, 2015 08:13 PM
