electrical connector replacement: valve timing control solenoid connector
Old Jul 27, 2013 | 04:06 PM
speedk1ng's Avatar
Wound up with a mangled valve timing control solenoid connector after shredding a supercharger belt. Talked w/Nissan and Infiniti....they don't offer an OEM electrical connector replacement...simply the entire engine harness.
Here is the connector:
Anyone have an idea where to cross reference this connector aftermarket so I can replace it?
--Sk
Old Jul 28, 2013 | 03:49 PM
speedk1ng's Avatar
Here is the identical connector on the other side of the engine for the other valve timing solenoid.....
However, plugging those p/ns into Google doesn't seem to given any information on the connector.
--Sk
Old Jul 28, 2013 | 04:12 PM
speedracerg35's Avatar
Weather pack connector. If you have access to some usable length of wire you can replace both sides. It may even be comparable to what is there.
Old Jul 28, 2013 | 04:18 PM
speedk1ng's Avatar
This connector plugs into the variable valve solenoid....no changing the other 'side'....
I've sent emails and photos off to these guys to see if they can cross reference the p/ns on the connector:
http://www.bmotorsports.com/shop/ind.../cPath/109_222
--Sk
Old Jul 28, 2013 | 04:28 PM
Salvage yard, search for maxima, Altima, g with a vq and snip off the connector??
Old Jul 28, 2013 | 04:36 PM
speedk1ng's Avatar
It might come down to that if I can't find a new one........
Old Aug 5, 2013 | 03:37 PM
bythabay's Avatar
I have an engine wiring harness available that I have been chopping up... do you need the harness side or the component side?
Old Aug 5, 2013 | 03:46 PM
speedk1ng's Avatar
harness side.....
Old Aug 7, 2013 | 06:03 PM
bythabay's Avatar
sorry for the delay, but I just got back from mailing you the connectors at the post office.
Old Aug 7, 2013 | 07:07 PM
speedk1ng's Avatar
No worries....thanks for doing that.
Old Aug 7, 2013 | 07:27 PM
bigc's Avatar
Wings Nation
glad it worked out for you, but be thankful you didn't fry your ECU as has happened to a handful other people when a S/C belt takes out that connector
Old Aug 7, 2013 | 07:37 PM
speedk1ng's Avatar
I hadn't heard about that one....so indeed, I got lucky.
Only one wire had the insulation stripped and luckily it apparently didn't ground out. It might be worth looking at fabricating up a guard to keep a shredding belt from eating that connector again in the future.
Old Aug 7, 2013 | 11:11 PM
bigc's Avatar
Wings Nation
^ check out this thread: http://my350z.com/forum/forced-induc...-cog-belt.html
Old Aug 8, 2013 | 10:01 AM
speedk1ng's Avatar
Hasanbaloch
Feb 29, 2024 08:45 PM
Muski_G
Dec 1, 2023 11:11 AM
EliteG
Engine - Electrical
Aug 5, 2015 07:50 PM
KevinnnVo
Jul 28, 2015 06:29 PM
apintojr
Jul 23, 2015 10:52 AM
