Over heating!!
Old Sep 4, 2013 | 07:45 PM
Cjyoung05's Avatar
Over heating!!
Ok so I had a bit of a scare the other day. After about an hour of driving I started to sit in traffic. I had the air conditioning on and I was moving my vent when I noticed on the dash that it was starting to over heat. The temp gauge was about near the top when I shut my car off. Whenever I started to move the temp went back down. When I was finally able to get to where I was going I opened the hood and looked at the fans and they were working. So I guess my question would be what else could be the problem? It's a 2005 sedan M/T and the car has 56,xxx miles on it. I don't know if these motors have thermostat issues or anything like that but I was hoping someone had an answer before I started replacing random parts. Hopefully I gave enough info but any suggestions would be great! Thanks
Old Sep 5, 2013 | 11:31 PM
Cjyoung05's Avatar
44 views and no one has any input??!!? Smh
Old Sep 6, 2013 | 01:50 PM
FARGonaz's Avatar
Seriously, you have given them virtually nothing to go on. If you're worried, take it to a friend who is mechanically inclined, or take it to a shop. Otherwise, do some searching, as there are plenty of 'overheating' threads.
Good Luck!
Old Sep 7, 2013 | 03:10 AM
jookyshank's Avatar
I haz hugz to givez
Check for blockage between your AC condenser and the radiator, this happened to my sedan and after removing some grit chunks (just build up of some random debris over 8 years I guess) she hasn't had an issue even on the 100 degree days *fingers crossed* OH I should mention that I replaced the thermo just in case and it still spiked on me once after that so the debris was the next step
Old Sep 7, 2013 | 10:50 AM
Cjyoung05's Avatar
Thank you jookyshank. I will try that!!
Old Sep 7, 2013 | 06:30 PM
Stillen06coupe's Avatar
bubbles in coolant system? try bleeding the system first since that is free
Old Sep 9, 2013 | 12:00 PM
seymore4's Avatar
m56
So you got it fixed?
Old Sep 9, 2013 | 02:07 PM
jookyshank's Avatar
I haz hugz to givez
Seems so...no issues since the cleaning
Old Sep 9, 2013 | 02:11 PM
WhosUrBuddiee's Avatar
Try peeing in your radiator. Urine has a much higher boiling point than water and will help.
Old Sep 9, 2013 | 02:17 PM
seymore4's Avatar
m56
nice, glad it was something simple. Now quit off roading with it!!
Picture Share
Feb 4, 2018 12:41 PM
DRG35R
Jan 31, 2016 07:14 AM
BradMD_96
Oct 6, 2015 09:31 AM
hrdwirk1
Oct 2, 2015 06:34 PM
