Help Engine Sputters than stalls.
Old Sep 22, 2013 | 09:32 PM
Senko's Avatar
I have a 2005 g35x with 125k. It was driving fine on the highway for over 2 hours. I even stopped for 30 minutes in between the hours. I parked back at home went to drive to the store and then she sputters and stalls out right in front of my place. I try and start it and then the same thing. Sometimes she starts even and around 1k rpms but then dies and sputters. I am completely baffled.
Possible issues I am thinking at the moment,
Spark Plugs
Clogged Injector
Clogged filter
Bad pump
or the dreaded lost compression (please god no)
Any ideas? please? help!
Old Sep 22, 2013 | 09:42 PM
herrschaft's Avatar
Any codes?
You should check the throttle body as well to see if there's any build-up around the butterfly.
Old Sep 22, 2013 | 09:47 PM
Senko's Avatar
I am going to have it towed somewhere tomorrow. havent read the codes yet as I dont have a reader. But I do smell fuel after it tries to start then dies coming from the exhaust.
Old Sep 22, 2013 | 10:03 PM
Senko's Avatar
but dont stop prodding cause I have heard the horror storries of similar situations and mechanics baffled as well. I am fairly tech savy I will check the intake tomorrow, and see if the TB is turning smoothly. Any other ideas? I dont really want to take the manifold off to check the spark plugs and injectors.
Old Sep 23, 2013 | 03:33 PM
reverse's Avatar
I'm going thru the same issue as well. It might stall when ever i come to a stop. The rpm drops completly after a high rev...
Old Sep 27, 2013 | 10:35 PM
Nate_6mt's Avatar
Check your cam/crank position sensors. Sounds like that's your issue...common problem with Nissan and infiniti
Freeman186
Sep 6, 2023 10:07 AM
alessandro
Oct 8, 2015 09:29 AM
Joe Gargano
Sep 18, 2015 11:17 AM
AT23
Sep 15, 2015 07:44 PM
AuAltima3.5
Sep 13, 2015 10:53 AM
