HR Cams and heads on a VQ
Old Oct 17, 2013 | 07:29 PM
IllestVQsedan's Avatar
As anyone tried to put the HR head and cams on the VQ motor? If so, what all did you have to change? A lot of work? Power gain? Etc..
Old Oct 17, 2013 | 07:43 PM
danoman32's Avatar
I think I've seen this same question asked recently. They are not compatible if I remember correctly. Search.....
Old Oct 17, 2013 | 07:52 PM
Glover997's Avatar
What do u mean by HR head n Cams in a VQ motor ?!
You meant In a DE motor ?
Old Oct 17, 2013 | 11:36 PM
Yes I meant VQDE! Lol sorry typo
Old Oct 20, 2013 | 10:00 AM
Glover997's Avatar
^ no problem .. It happens with great families too
أخذنا ده ٨ وجلبنا أمه كده ٧
Old Oct 20, 2013 | 02:24 PM
bluedevils95's Avatar
Why don't you get a spacer for the best gains?
Old Oct 25, 2013 | 02:21 PM
TunerMax's Avatar
G35
They can be used but I don't know exactly how and I do know that it changes the compression ratio.
Old Oct 25, 2013 | 02:47 PM
WhosUrBuddiee's Avatar
Yes it can be done I believe. The question is why? ALOT of work for very little gain.
The HR has exhaust CVTC and the DE does not. So you would need an HR ECU or standalone. Also HR has 2 additional cam sensors. HR also has larger oil pump that is necessary and will not bolt to DE.
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
g.spot
May 9, 2016 10:54 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
BradMD_96
Oct 6, 2015 09:31 AM
