Codes p0102, p0113, p0223, p0123, p2135, all TPS related what do I do?
Old Nov 26, 2013 | 08:52 PM
  #31
ChrisKG35's Avatar
I assume this would explain the issues correct?
Old Nov 27, 2013 | 08:00 AM
  #32
brazen's Avatar
It very well may. We'll just need to rule this out before moving on to anything else since you're hearing the loud hissing sound. When the car is at operating temperature, it's in a closed loop meaning all sensors have an effect on the fuel/air ratio. If you have a major vacuum leak, this could cause an extremely lean ratio as air is entering the combustion chamber not metered by the MAF, leading to a non start. If you do have a large vacuum leak, then it should be fairly easy to find with the TB cleaner method above.
Good luck!
Old Dec 1, 2013 | 11:27 PM
  #33
ChrisKG35's Avatar
Wow didn't see this, I have carb cleaner, that should be fine correct? You seem knowledgable, the loop ran through my head but I wasn't really sure if that was a reason but it does make sense now. If this doesn't work I'll have to take it to a shop but hopefully I don't get stranded with a car that's not starting. Thanks, will get back to you.
Old Dec 3, 2013 | 05:18 AM
  #34
brazen's Avatar
Yes, carb cleaner will work just fine.
Marlin84
Apr 1, 2020 12:52 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Detailed Image
Sep 28, 2015 07:04 AM
vamarris
Sep 26, 2015 12:56 PM
doakley92
Sep 25, 2015 12:58 PM
