To change transmission fluid or not to change, that is the question
Old Oct 31, 2013 | 06:38 PM
carl-in-nh's Avatar
In spring 2013 I bought a used 2008 G35x (AT), 62k miles when I got it, 72k miles now.
Infiniti recommends the transmission fluid be replaced every 30k miles (exact verbiage is: "Replace automatic transmission fluid" -- I assume they mean a drain/refill, not a flush)
Service records do not show that the previous owner did any tranny fluid replacement, and I also doublechecked this with the local Infiniti dealer, where the previous owner seemed to diligently take their car for the necessary regular service.
I have no current issues that suggest I have a problem with the fluid that I need to address (no burnt smell, etc).
So, my question is: should I go ahead and start regularly doing the tranny fluid replacement, or should I leave well enough alone for now ?
Old Oct 31, 2013 | 07:47 PM
saywat?'s Avatar
im jus guessing here but doesn't it say to change it every 30k if ur towing?
Old Oct 31, 2013 | 08:00 PM
kpowe1's Avatar
Yes I say go ahead and do it, 72k isn't a lot of miles. I did mine at 172k and everything was fine, now have 223k and it's still going strong.
Old Oct 31, 2013 | 08:02 PM
carl-in-nh's Avatar
Good point. Checking again, I was looking under the "Premium Service" recommendation list, which says to replace, no caveats. However, under the "Schedule 1 and 2" service level list, it does have a note to "replace, not just inspect", if towing a trailer.
So, it seems to me that the replace should be done only if a) you are towing or b) if you believe the "Premium" level service recommendations have merit.
I don't tow, and am a bit more conscious of cost/benefit than that, so I will stick with the "inspect" for now.
Thanks for pointing that out.
Old Oct 31, 2013 | 08:05 PM
saywat?'s Avatar
ive always felt that the premium service is a super precaution maintenance like if ur super paranoid. also a way for the dealerships to make money lol. that's jus my imo
Old Oct 31, 2013 | 08:12 PM
Eric@TCGMiami's Avatar
What is cheaper oil or replacement of a transmission?
If your NOT sure. Have it replaced.
Old Nov 2, 2013 | 05:57 PM
superchargedg's Avatar
replace it for peace of mind at least
Old Nov 2, 2013 | 06:06 PM
saywat?'s Avatar
yes replace for peace of mind. so u can start your own record keeping but I would not change it every 30k miles after that.
Old Nov 2, 2013 | 11:20 PM
a471133's Avatar
Drain and fill is pretty simple to complete. If you can change engine oil you can do the drain and fill in half an hour.
Old Nov 3, 2013 | 01:27 AM
redonblack35's Avatar
Like everyone here said, drain and fill is super easy, and worth it for the piece of mind. Thenismoshop.com has the most competitive rate I've seen for the oil. Also super speedy shipping!
Old Nov 14, 2013 | 02:55 PM
vashawn's Avatar
I'm about to do a drain & fill this weekend also
just a quick question can i use an aftermarket auto tran fluid like redline etc or should i go with nissan?
@ 120k right now. and the last time i did a drain & fill was @ nissan around 80K
Old Nov 14, 2013 | 03:30 PM
saywat?'s Avatar
id go oem
derres
Aug 28, 2015 03:27 PM
NemesisGee
Aug 11, 2015 07:10 PM
Srinidhi
Aug 7, 2015 03:38 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
