TC-W3 marine two stroke oil as a gasoline additive
Old Nov 13, 2013 | 06:55 PM
Babyseat's Avatar
Originally Posted by WhosUrBuddiee
I suggest using Nissan recommended ester oil. Personally I tend to trust teams of highly educated engineers with decades of experience, opposed to a handful of guys of a forum pouring random crap from autozone in their cars. Just because your car sounds like a lawnmower, doesnt mean you should put lawnmower oil in it.
You trust the people who have admitted to an oil consumption problem but refused to fix the problem( for less then $15k) if it was unnoticed until after the warranty period?
Originally Posted by JayVQ
I have to admit I am curious about this and it is all over the net with people using it and claiming positive results. I am also interested in the long term affects since it seems this does go back a ways but have yet to find anyone posting results from several thousand of miles of usage.
What he said ^
Old Nov 13, 2013 | 07:39 PM
WhosUrBuddiee's Avatar
Oil consumption is caused by ring wear. There is nothing you can do to fix the problem except rebuild the engine. Dumping some weedwacker oil in your gas tank is only going to make the problem worse.
Old Nov 13, 2013 | 08:13 PM
BobPezz's Avatar
As I said before being 'Trolled'... I used it in my 2001 Maxima for ~3yrs/40kmiles. w/ good results. The engine ran great, but rust never sleeps so it had to go. So far I'm up to almost 4k in the G35x. I'm noticing the typical results; decreased engine noise/vibration, +2-3mpg(city) & better low end throttle response. If the G35x follows the same route as the Maxima, it'll continue to improve over time. It takes a while to get the full benefits as the deposits clean out of the engine. If nothing else TC-W3 could be an economical way to reduce the detrimental effects of ethanol/contaminants in fuel. I hope this helps.
See the originating thread. http://www.ls1.com/forums/f48/been-t...6/#post1545356 Granted it's >50pages but there are ~5yrs. of posts. There may be other forums w/ long term users.
Old Nov 14, 2013 | 04:26 PM
Babyseat's Avatar
Maybe there is some unseen reason it works, but as far as the ring wear is concerned I have never had another motor nor do I know of another motor with such an oil consumption problem that the manufacturer has done nothing (again for the people who did not notice the problem until warranty had run out) to rectify the problem when they have admitted to a design flaw
Old Nov 14, 2013 | 04:39 PM
Jeff92se's Avatar
Red Card Crew
2 stroke oil is known for causing ring deposits but you suggest using it to lower ring deposits. I dont see your logic. That is like using a high carb diet to loose weight.
Why can't you eat high carbs and loose weight? As long as the calorie count is lower than your expenditure, you will net weight loss.
Looks like you owned yourself there genius
Old Nov 14, 2013 | 04:41 PM
Babyseat's Avatar
You make a very good point sir
Old Nov 14, 2013 | 06:20 PM
BobPezz's Avatar
Interesting that the VQ30 series had no oil burning problems even after >200k miles. There's a lot of controversy on this issue, since it doesn't affect all VQ35 engines. One theory is that it's due to changes in the VQ35 PCV system. Which causes the ring packs to gum up & not seal properly against the cylinder wall. That could account for some reports that TC-W3 may reduce oil consumption. As the ring packs are cleaned, they seal better, oil consumption drops.
If you have an oil consumption problem it's worth trying, what have you got to lose? A few dollars for a qt. of oil. My use of TC-W3 as a preventative measure, will hopefully make oil consumption a non-issue.
Old Nov 14, 2013 | 06:49 PM
BobPezz's Avatar
Good point! That said, the genius 'Troll' kept harping on the 2-stroke oil aspect of the thing. It's a minor factor, the 2-stroke oil is used @ 1oz./4-5gals.of fuel = 512-640/1 ratio. Over 100 times less than what's used in a 2-stroke engine. In even the best top tier fuels, there's likely to be a higher concentration of water & contaminants in the 10% ethanol. The oil is just a good way to get the TC-W3 additive package into the fuel system, since 2-stroke oil is meant to mix w/ gas.
Old Nov 14, 2013 | 07:58 PM
Also interesting that the VQ30 isnt known for having oil burning issues. Who would have that thought that dumping weedwacker oil in your gas tank would help to prevent a non existent problem.
Cleaning the ring build up would not lessen oil consumption. The one any only way to lessen oil consumption is rebuild the engine.
Old Nov 14, 2013 | 08:17 PM
GR6RR's Avatar
Old Nov 14, 2013 | 08:46 PM
BobPezz's Avatar
Originally Posted by GR6RR
No popcorn needed. The ignore list is a great 'Troll' repellant!
Old Nov 14, 2013 | 10:43 PM
Urbanengineer's Avatar
Old Nov 15, 2013 | 08:04 AM
BobPezz's Avatar
The ignore list is the best 'Troll Repellent' on the site. I don't have to put up with the 'Trolling' ish!!!
Old Nov 15, 2013 | 08:57 AM
At least you finally posted something worthwhile in this thread. I was serious about giving you a job BTW. I do quite a bit of work at Pilgrim station in your area, we have a very big project going on right now and could use some more construction support (as long as you are not a union piece of sh*t).
Old Nov 15, 2013 | 01:07 PM
  #30
Jeff92se's Avatar
Red Card Crew
Had to laugh at that one. Fits like a friken' glove
