TC-W3 marine two stroke oil as a gasoline additive
Old Nov 15, 2013 | 03:42 PM
  #31
GR6RR's Avatar
I just barely noticed the reflection on the lens.
Old Nov 19, 2013 | 10:11 AM
  #32
Tolboothwilley™'s Avatar
I spent a ton of time reading about this on various forums throughout the net. I think I'm gonna try it out on a car of mine and test the results.
Old Nov 20, 2013 | 07:42 PM
  #33
BobPezz's Avatar
<IMHO> An informed conclusion. I don't know if you saw this on Maxima.org, but a 9dB reduction in engine noise probably indicates a beneficial result.
"TC-W3 marine two stroke oil as a gasoline additive - NEW
So after the last thread on this here disappeared, let's get another one going.
http://www.ls1.com/forums/f48/been-testing-91206/
^^ the original thread over on LS1.com, with research and oil analyses and what-not...
But the gist of it is this:
*adding ONE OUNCE of TC-W3 rated 2-stroke marine oil to 4/5 GALLONS of gas at each fill-up does wonders for our vehicles.
* TC-W3 is ash-less, so it's clean burning.
*Smooths out and quiets down the engine. I have PERSONALLY taken decibel readings both before and after adding TC-W3 to my gas tank, and the engine runs 9dB quieter at idle. About 15 percent quieter, that's verified!
*Also, it has been reported that some users get better mileage with it ( I personally do not, but I tend to drive on the energetic side anyhow)
*Cleans out the injectors and top end of carbon and deposits
*lubricates the fuel delivery system
*does NOT harm O2 sensors / catalytic converters / emissions equipment at all.
*reduced hydrocarbon emissions (CLEANER EXHAUST)
It is available at auto parts stores, Wal-mart...wherever. The ONLY stipulation is that it has to be TC-W3 rated. Brand is not relevant. It's cheaper than MMO, Techron cleaner, Seafoam...all of it."
Old Dec 2, 2013 | 07:06 PM
  #34
BobPezz's Avatar
Have you tried the TC-W3 yet? Bear in mind, it takes at least 2-3 tankfuls to notice a difference & 1oz./4-5gals. of fuel is the best ratio for our cars. You may want to initially try 1oz./4gals. & 1oz./5gals. after several tankfuls.
Old Mar 22, 2014 | 11:55 AM
  #35
BobPezz's Avatar
I just bought my 2nd. gallon of 'Walmart' brand TC-W3 2-stroke oil, since I started using it in my Maxima. I started running it in the G35x when I got the car w/ ~ 66K miles. It initially used about 1/8" on the dipstick worth of oil during the 1st. 1K miles & stopped using oil at that point. I'm now about 1/2 way through my 2nd. oil change interval since owning the car & have seen ZERO oil use. Could be the Nissan dealer used better oil or the TC-W3 worked. I'm not sure which stopped the oil use. But it appears that shortly after I started using TC-W3 there was reduced oil use during the 1st. oil change interval. At 1oz./4-5gals. of gas the other benefits i.e. smoother/quieter running engine, slight gas mileage & low end power improvement. It's worth $13/gal. every few years, measuring out 3-4oz. per fill-up & pouring it in the gas tank. <IMHO>
Old Mar 24, 2014 | 12:51 PM
  #36
I ran this for several tanks in my 4runner - and noticed no differences at all. I have since stopped running it. I never did try it in my G
Old Mar 24, 2014 | 08:10 PM
  #37
BobPezz's Avatar
That's interesting... You're the first I've heard of that didn't notice any difference at all. Guess as they say "your mileage will vary". Perhaps the VQ engine is more sensitive to TC-W3 in fuel than some other engines. I commend you for at least giving TC-W3 a try. Unlike the naysayers, that just criticized the concept.
Granted, I found out about the thread on the Maxima forums & though skeptical tried TC-W3 just as an experiment in my Maxima. I and many other Maxima enthusiasts got good results. I noticed pretty much the same good results w/ my G35x. I'm just glad TC-W3 appears to have helped reduce my oil use to zero.
g.spot
May 9, 2016 10:54 PM
yosip1115
16
Sep 28, 2015 04:14 PM
inexorable
17 Inch
Sep 24, 2015 10:43 AM
CV35Driver
Sep 15, 2015 05:09 PM
