Auto 2004 G35 engine into manual 2003 350z
Old Dec 23, 2013 | 08:46 PM
ceano's Avatar
as the title specfies... will the auto g engine bolt right into the 350z+ wiring harness or will more parts be needed? i have a totaled 04 g35 and im looking to put the engine into a 2003 350z
Old Dec 29, 2013 | 12:06 AM
bythabay's Avatar
03 04 g z motors are the same, you shouldn't have any issues.
Old Dec 29, 2013 | 10:46 AM
superchargedg's Avatar
Everything should match perfect but you will need to install a new pilot bearing for the manual trans.Napa part #0780701
Old Dec 29, 2013 | 11:31 AM
Conway_160's Avatar
I just had an 04 auto motor put into my 04 6mt so you will have no problems.
Old Jan 6, 2014 | 07:59 PM
dbarnes's Avatar
Hey Conway, curious - why did you need a new engine in your 2004 6MT ?? Was it just tired, or did it fail in some way ??
I also have a 2004 6MT with 115K miles on it, ran great until a large chunk of an exhaust valve on cylinder #4 decided to vacate the motor this past July 4th, resulting in complete loss of compression in #4. Left some pits and scratches but cleaned up well when I took it to the machine shop and had the heads completely rebuilt with a 5 angle performance valve grind to boot..
Minor scratches on cylinder wall #4, but everything appeared OK so we put the rebuilt heads back on and thought "good to go". Has over 180 lbs. compression in every cylinder (max per manufacturer), is snappy and runs like a scalded dawg, and idles as smooth as it ever has. Problem is that it keeps fouling the plug on cylinder #4 and the plug is covered with oil and deposits - going through a quart of 5/30 wt every 500 miles or less now. Prognosis is that I have a broken oil ring on #4, while compression rings are just fine - which sucks. Kind of like a world class athlete who is at the top of his game, but is diagnosed with an aggressive cancer and won't live another year!
Looks like I've gotta get a new motor myself, so thanks for the info on the interchangeability of auto and stick motors (didn't think there was a difference, but ya never know).
Just curious ....
vmcarbuyer
Oct 12, 2019 12:42 PM
brycealbr
Aug 11, 2015 11:47 AM
igking
Jul 19, 2015 01:12 AM
G35OUTLAW6MT
Jul 13, 2015 02:26 PM
