Where do you get Amsoil?
Old Feb 8, 2005 | 04:25 AM
dwoloz's Avatar
Do you guys buy online or is there a store I can find it at?
Looking for 75-90W gear oil for the diff
Old Feb 8, 2005 | 04:13 PM
Brando's Avatar
Won't that void your factory warranty???
I thought you had to use what the manual recommends or they look for ways not to cover problems.
Old Feb 8, 2005 | 04:34 PM
dwoloz's Avatar
The thing I heard was that you have to use Nissan transmission fluid but for the differential, you can use something else. The Amsoil gear oil is apparently the same color as the Nissan fluid so I dont think it will raise any questions
For Inftiniti to not honor warranty they have to prove that what you did lead to the problem. Its clearly stated by them in their literature that if you dont use their tranny fluid then your warranty will be void. I havent found anything like that for the differential though
Old Feb 12, 2005 | 11:28 AM
ZeroGen's Avatar
Omega Enthusiast
You could buy Amsoil online but there are distributors where you can order this and other products. I don't know one off the top of my head but they're around...
Old Feb 12, 2005 | 12:27 PM
ballisticus's Avatar
This is what you want https://www.amsoil.com/storefront/svg.aspx
I have had Amsoil in the diff since 3000 miles, and changed it again at 42000. My mechanic said there was nothing on the magnetic drain plug at all, not even the grey paste. This will not void your warrantee because you diff will never fail when using this. Unless, or course there is a manufacturers defect that lead to the failure. Just put it in there and keep quiet. The dealer doesnt need to know everything anyway. The less they know the better since any knowledge will be used against you anyway.
heynow
2nd Gen (V36) Sedan
Oct 28, 2015 05:09 PM
IkonG35
Aug 10, 2015 09:33 AM
fortified
Intake & Exhaust
Sep 17, 2006 02:29 PM
ILust4G
Feb 9, 2004 11:33 AM
