2004 Infiniti G35 coup
Jul 7, 2014 | 12:08 PM
Hi Guys i need some help!!
My Problem:
I turned my car on this morning and had the Service Engine Soon light along wit the VDC PFF and SLIP Light all on. I was late for work so i drove the car like that and the car was driving just fine. I was going about 120 km/h on the highway and engine was running smooth. Some other threads i read that have had similar problems were having power losses and car was not accelerating, and car was acting weird, but for me everything runs as it should but the lights are on. Any one have any ideas as to what is going on??? Thanks
Reply 0
Jul 7, 2014 | 01:07 PM
try adding some brake fluid! I had the same problem added some brake fluid and no problem ever since.
Reply 0
Jul 7, 2014 | 01:11 PM
Quote: try adding some brake fluid! I had the same problem added some brake fluid and no problem ever since.
agreed..
also.. when some lights turn on for the first time.. i wouldn't drive that fast.. just in case...
Reply 0
Jul 7, 2014 | 03:48 PM
Please do not add brake fluid. Typically, no car should ever need brake fluid added except when changing the fluid.
The only way to find out what is going on is to retrieve the trouble code by connecting a OBD scanner to the vehicle. I can tell you, if all three lights are on, it's a good indication a serious fault was found by the computer and you should not be driving the vehicle because you can cause damage to your vehicle.
Reply 0
Jul 7, 2014 | 05:37 PM
+1 check the brake fluid first..
Reply 0
Jul 8, 2014 | 07:09 AM
Ok guys i have an update on the problem, i read on other threads that if the gas cap was on tightened that the lights would come on, sure enough i did not have the gas cap on and once i tightened it the VDC and SLIP light turned off but the SERVICE ENGINE SOON LIGHT is still on. Any thoughts on why the service light is still on?? Thanks
Reply 0
Jul 8, 2014 | 08:58 AM
Quote: Ok guys i have an update on the problem, i read on other threads that if the gas cap was on tightened that the lights would come on, sure enough i did not have the gas cap on and once i tightened it the VDC and SLIP light turned off but the SERVICE ENGINE SOON LIGHT is still on. Any thoughts on why the service light is still on?? Thanks
Not related. What are your tire sizes.
Reply 0
Jul 8, 2014 | 10:02 AM
225/45/r18 in the front and 245/45/r18 in the rear!
Reply 0
Jul 8, 2014 | 01:07 PM
One the engine light is on it takes about 200 miles of driving before it resets. It should go off, but it takes a little while.
Reply 0
Jul 9, 2014 | 12:24 AM
Quote: 225/45/r18 in the front and 245/45/r18 in the rear!
Stock sizes, that's out the window. Hmm...
Reply 0
Jun 21, 2017 | 11:06 PM
Power loss. F
sup guys . I have a 04 g and I jus got my clutch replaced .. soo I went to go pick up the car and I noticed it was not driving how it should ! Guy told me I had to change the spark plugs did that . So, I went to drive the car and it feel like it's losing power , bcuz I give the car gas and the RPMs seem to be delayed and car picks up slow . Can't even make it to read line highest it ever went was about 4K RPMs ... can anyone help plz an thanks!
Reply 0
Jun 29, 2017 | 03:18 AM
Quote: sup guys . I have a 04 g and I jus got my clutch replaced .. soo I went to go pick up the car and I noticed it was not driving how it should ! Guy told me I had to change the spark plugs did that . So, I went to drive the car and it feel like it's losing power , bcuz I give the car gas and the RPMs seem to be delayed and car picks up slow . Can't even make it to read line highest it ever went was about 4K RPMs ... can anyone help plz an thanks!
wondering if the flywheel was re-installed properly when the clutch was installed. if i'm not mistaken there is a dowel on the crank that will properly locate the mark on the flywheel for the TDC sensor, but maybe it was removed and is out of time now as a result??
Reply 0
Jun 29, 2017 | 05:43 AM
Quote: wondering if the flywheel was re-installed properly when the clutch was installed. if i'm not mistaken there is a dowel on the crank that will properly locate the mark on the flywheel for the TDC sensor, but maybe it was removed and is out of time now as a result??
Thats the thing ! Clutch feels great I'm not having any problems with that . But guy told me I'll need a new timing chain -_- my car didn't need one when I dropped the car off to get the clutch installed smh ! && I noticed when he got done with the clutch , he went to go test drive the car .. sure enough the oil dip stick was bone dry 🙄🙄🙄 now my car is throwing a code p0011 passenger side smh ...
Reply 0
