HELP! Kinetix Intake plenum install problems
Old Jul 23, 2014 | 01:10 AM
P-townG35's Avatar
Hey guys, i just purchased a used Kinetix v+ upper intake plenum for my 03 G35 coupe, and when i went to start the car it would rev high then have low pulsating revs then die. there was also a strong smell of gas. I did notice the 6 bolts inside the plenum that the kinetix deleted from the oem one had open bolt holes. they didnt seem to go anywhere so i didnt worry about them? I know my gasket is seal properly, all the lines are properly connected and so forth. Any suggestions? did i need to put bolts on the inside even tho nothings there? thanks guys
Old Jul 23, 2014 | 01:14 AM
BowWizzel's Avatar
Maybe needs a idle relearn
Old Jul 23, 2014 | 01:16 AM
P-townG35's Avatar
thanks for the quick reply. an idle relearn? is there a link where i could do that? or a scan tool? i tried unplugging the battery for 15 mins. no luck. i did also install a tbs as well, so maybe thats the problem?
Old Dec 8, 2014 | 09:43 AM
AutoX Junkie05's Avatar
P-town .... Did you find a solution to your problem????? I'm planning on getting the Kinetic SSV plenum for my 05 very soon. Would anyone recommend a different plenum???? I'm a Canadian resident so there might be a chance I can't order something's available in the USA.
Old Dec 9, 2014 | 11:37 AM
P-townG35's Avatar
It was a simple solution. I bought the plenum used, it didn't come with shorten bolts for the center of the plenum that the full kit comes with. I filled those exposed holes in the center with shortened bolts and the problem completely went away!
Old Dec 9, 2014 | 05:31 PM
dsr30's Avatar
Has your butt dyno realized any performance increase?
Old Dec 10, 2014 | 08:23 AM
P-townG35's Avatar
after install, I did notice a better steady pull through general acceleration.. nothing huge, but I think it was worth the money. I did just get the uprev tune a couple weeks later, and I was VERY satisfied with that.
Old Dec 10, 2014 | 09:54 AM
dsr30's Avatar
Cool, thanks for the info.
chinee
Jun 10, 2024 07:48 PM
Tukeeg35
Engine - Intake/Fuel
Aug 21, 2015 04:19 PM
Herbbie Hablib
Forced Induction
Aug 11, 2015 06:22 PM
wuppiedog
Aug 7, 2015 11:16 AM
lemmy999
Jul 25, 2015 12:13 PM
