04 G35 sedan SES light up after mods! Need help
Old Aug 20, 2014 | 05:22 AM
mliu66's Avatar
BTW, does everyone use OEM sensor or aftermarket sensor? I bought a dirty cheap knock sensor and the seller said it is the same, not sure if it can work as original sensor.
Old Aug 26, 2014 | 04:41 PM
ray1370's Avatar
I use an aftermarket sensor, it works fine and it should outlast the harness lol. Just make sure the plug fits.
Old Sep 4, 2014 | 06:20 AM
mliu66's Avatar
I just noticed there is a hole in front of the engine block, from where I can see the sensor. I am wonder if it is possible to use some long reach tools to get it replaced without opening the intake...
Old Sep 6, 2014 | 07:23 PM
mliu66's Avatar
OK got a problem. The harness is mounted on a bracket under the car, should that be removed and then reinstalled? It's hard to take the harness off from the clip under the car
Old Sep 9, 2014 | 09:33 PM
ray1370's Avatar
If you can fit the tool in then you can take the bracket off. Or you can try wiggling the connector and pushing up to make it slide out of the bracket.
Old Sep 14, 2014 | 05:51 AM
mliu66's Avatar
Finally done. The harness bracket is a PITA, was lucky to take it off.
Hasanbaloch
Feb 29, 2024 08:45 PM
Mry
Mar 3, 2023 01:03 AM
mjfenix
Jul 24, 2015 05:16 PM
sick_sixspeed
Jul 21, 2015 01:59 PM
Tony_Me22
Jul 17, 2015 06:30 PM
