Catch can set up
Old Oct 14, 2014 | 07:39 PM
6spdGspot's Avatar
Catch can set up
I understand where to install the catch can. Just wanted tokn
Old Oct 14, 2014 | 07:58 PM
Lartytiejdke3's Avatar
OP got attacked half way through his post.
Old Oct 14, 2014 | 08:07 PM
6spdGspot's Avatar
Catch can set up
I understand where to install the catch can. Just wanted to know if it is better to run a drilled out PVC valve or a non drilled out one.
-thanks
Old Oct 15, 2014 | 04:58 PM
saywat?'s Avatar
why would u want to make the pcv valve non functional?
Old Oct 17, 2014 | 06:53 PM
6spdGspot's Avatar
"Use a non-drilled PVC valve"
^^that answer would suffice. Not a question for a response to my question.
Old Oct 17, 2014 | 08:52 PM
ScraggleRock's Avatar
Haha OP is a pro. Straight troll rolled the trollers.
Old Oct 17, 2014 | 11:09 PM
6spdGspot's Avatar
I guess I couldn't expect any less from "saywat?"
^^it is in fact a question.
Old Oct 18, 2014 | 12:44 AM
gary c's Avatar
Originally Posted by 6spdGspot
I understand where to install the catch can. Just wanted to know if it is better to run a drilled out PVC valve or a non drilled out one. -thanks
Leave the PVC alone with the exception of cleaning it once in a while! Here's how I installed my first catch can...Search using those two words "Catch Can!" That will show you where to install the lines to the catch can and what kind of hose to use...Gary
Old Oct 18, 2014 | 08:24 AM
6spdGspot's Avatar
Thank you Gary. I appreciate the help!
Old Oct 18, 2014 | 01:16 PM
HotRodG35's Avatar
If your FI than drill out PCV and use a check valve on return line to intake. I used a MOROSO oil sump check valve.
If NA leave check valve alone.
boostelevator
Engine - Intake/Fuel
12
Jan 12, 2016 11:35 PM
mbe32
Interior
Oct 1, 2015 09:47 AM
Red G Coupe
Video Share
Sep 6, 2015 06:45 PM
johnadlertech
Lights
Sep 4, 2015 12:35 PM
