Any "Limited Slip Diff" Guru here ??
Old Nov 16, 2014 | 12:25 PM
randyc's Avatar
Looking for someone who really knows about Limited Slip Diff .
I have more wear on my Back Right tire , and it is not due to PSI, or Alignement.
I wondering excactly how the LSD works ,and maybe could be the cause of Back Right tire wear?
I have a G35S Sedan .
Old Nov 16, 2014 | 12:33 PM
Lartytiejdke3's Avatar
Talk to herrschaft
Old Nov 16, 2014 | 12:42 PM
randyc's Avatar
Ok, He's a member i suppose ? I'll try to reach him, Thanks!
Old Nov 16, 2014 | 12:50 PM
yup yup
Old Nov 16, 2014 | 02:07 PM
ScraggleRock's Avatar
You don't need to be an expert to know how they work. Here's the important part: if you have more than 50-60k miles on the car, you no longer have limited slip, you have an open differential. LLLOOOOTTTSSS of cars have open differentials and don't have that kind of weird tire wear. Plus its not even that bad.
Old Nov 16, 2014 | 09:55 PM
randyc's Avatar
So on "normal" accleration are the Friction Plates in the LSD being solicitated, or are they only used in Hard accelerations when some slip occurs ??
Old Nov 16, 2014 | 10:54 PM
Hard acceleration.
Old Nov 17, 2014 | 12:52 AM
Dr.Bora's Avatar
mine has 176k and the diff still functions as it should...
Old Nov 17, 2014 | 02:06 AM
How are you guaging that?
Old Nov 18, 2014 | 11:21 AM
randyc's Avatar
If the VSLD isno longer functioning , could it just need New Diff Oil ??,, or can it actually Wear?
Old Nov 18, 2014 | 11:25 AM
Texasscout's Avatar
The friction plates naturally wear. IF you oil is BLACK, that's friction material in the oil.
Old Nov 18, 2014 | 11:37 AM
randyc's Avatar
So even if it's just the oil causing the friction , ..not actual plate on plate contact, they can still wear ?
Old Nov 18, 2014 | 12:44 PM
Texasscout's Avatar
it's the "plate to plate" contact that works the magic of the LSD. You have got to have it or you have a standard diff. Once the plates wear off the friction material, they start to slip. Really doesn't affect the day to day driving, just when you push it hard out of a tight corner.
Old Nov 18, 2014 | 12:55 PM
randyc's Avatar
....There is no Plate to Plate contact in a VLSD??
Its the Oil that causes the friction . That's what the V stands for, Viscous
Old Nov 18, 2014 | 04:34 PM
saywat?'s Avatar
wat if the car was never driven hard?
